YDK-Py installation made super simple!
saalvare
Starting with release 0.5.4, YDK-PY is now part of the Python package index (PyPi). This means a dramatically simpler installation experience.  Instead of downloading/cloning the YDK-Py code, building source packages and installing them in a particular order, you can just use the pip utility to automate the installation.  Previously, a full installation of YDK-Py (YDK core package, plus XR/OpenConfig/IETF) could take 12 steps.  Now, you just need to issue:
$ pip install ydk-models-cisco-ios-xr
If you already have YDK-Py installed and want to upgrade:
$ pip install ydk-models-cisco-ios-xr --upgrade
That's it.  That simple!
The installation process takes care of pulling all Python dependencies and install them for you.  Take into account that Python packaging doesn't handle system dependencies.  That is, non-python libraries and packages required by YDK-Py or by Python packages that YDK-Py uses.  You still need to install those system dependencies the first time you use YDK-Py.  See our updated installation instructions in the YDK-Py documentation.
Let's get hacking!
23 Replies 23
sofitapaul
How much time it will take to update?
for me it is taking more than 45 mins
That is interesting. Are you using a virtualenv? Which OS?
Is it getting stuck for you? or you're able to verify progress and validate installation after 45min?  Please share as many details about your environment as possible.   The longest it's taken for me is about 2.5 minutes.   In that case, I had a VPN session over a slow overseas Internet connection.
Hi ,
i am getting error like below , even i set proxy ... any idea how to fix ?
i used this proxy :source /auto/pyats/bin/lab_proxy.sh
[exec] baalagar@nkaliape-lnx-v1%>pip install ydk-models-cisco-ios-xr
Requirement already satisfied: ydk-models-cisco-ios-xr in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages
Requirement already satisfied: ydk-models-ietf>=0.1.1 in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: enum34==1.1.3 in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: ydk>=0.5.2 in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: lxml==3.4.4 in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: ydk-models-openconfig>=0.1.2 in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: ncclient>=0.4.7 in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: ecdsa==0.13 in /auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages (from ydk-models-ietf>=0.1.1->ydk-models-cisco-ios-xr)
Collecting paramiko==1.15.2 (from ydk-models-ietf>=0.1.1->ydk-models-cisco-ios-xr)
  Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fa777ecd278>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/paramiko/
  Retrying (Retry(total=3, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fa777ecd588>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/paramiko/
  Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fa777f3d9e8>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/paramiko/
  Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fa777f3d8d0>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/paramiko/
  Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fa777f384e0>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/paramiko/
  Could not find a version that satisfies the requirement paramiko==1.15.2 (from ydk-models-ietf>=0.1.1->ydk-models-cisco-ios-xr) (from versions: )
No matching distribution found for paramiko==1.15.2 (from ydk-models-ietf>=0.1.1->ydk-models-cisco-ios-xr)
Bala,
Can you verify http/https connection to other websites with the proxy config you have?
Cheers,
Einar
yes http and https connection went fine .
[exec] baalagar@nkaliape-lnx-v1%>ping www.cisco.com
PING origin-www.cisco.com (173.37.145.84) 56(84) bytes of data.
64 bytes from www2.cisco.com (173.37.145.84): icmp_seq=1 ttl=242 time=42.9 ms
64 bytes from www2.cisco.com (173.37.145.84): icmp_seq=2 ttl=242 time=42.5 ms
64 bytes from www2.cisco.com (173.37.145.84): icmp_seq=3 ttl=242 time=42.5 ms
ICMP traffic is not dealt with by an HTTP proxy and Cisco websites are usually not routed via the lab proxies. Can you use curl or wget with external websites?
on lab machines I usually use proxy.esl.cisco.com:80<http://proxy.esl.cisco.com:80> as the setting and that works fine. For example:
export http_proxy=http://proxy.esl.cisco.com:80/
export https_proxy=http://proxy.esl.cisco.com:80/
export ftp_proxy=http://proxy.esl.cisco.com:80/
export no_proxy=.cisco.com<http://cisco.com>
export HTTP_PROXY=http://proxy.esl.cisco.com:80/
export HTTPS_PROXY=http://proxy.esl.cisco.com:80/
export FTP_PROXY=http://proxy.esl.cisco.com:80/
Cheers,
Einar
Thanks Einar , it is installed properly after proxy set that you shared
[root@exr-idt-ucs ~]# pip install ydk-models-cisco-ios-xr
Requirement already satisfied: ydk-models-cisco-ios-xr in /usr/lib/python2.7/site-packages
Requirement already satisfied: ydk-models-ietf>=0.1.1 in /usr/lib/python2.7/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: enum34==1.1.3 in /usr/lib/python2.7/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: lxml==3.4.4 in /usr/lib64/python2.7/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: ydk-models-openconfig>=0.1.2 in /usr/lib/python2.7/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: ydk>=0.5.2 in /usr/lib/python2.7/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: ncclient>=0.4.7 in /usr/lib/python2.7/site-packages (from ydk-models-cisco-ios-xr)
Requirement already satisfied: pybind11==2.0.1 in /usr/lib/python2.7/site-packages (from ydk>=0.5.2->ydk-models-cisco-ios-xr)
Requirement already satisfied: setuptools>0.6 in /usr/lib/python2.7/site-packages (from ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: paramiko>=1.15.0 in /usr/lib/python2.7/site-packages (from ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: six in /usr/lib/python2.7/site-packages (from ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: cryptography>=1.1 in /usr/lib64/python2.7/site-packages (from paramiko>=1.15.0->ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: pyasn1>=0.1.7 in /usr/lib/python2.7/site-packages (from paramiko>=1.15.0->ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: idna>=2.0 in /usr/lib/python2.7/site-packages (from cryptography>=1.1->paramiko>=1.15.0->ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: ipaddress in /usr/lib/python2.7/site-packages (from cryptography>=1.1->paramiko>=1.15.0->ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: cffi>=1.4.1 in /usr/lib64/python2.7/site-packages (from cryptography>=1.1->paramiko>=1.15.0->ncclient>=0.4.7->ydk-models-cisco-ios-xr)
Requirement already satisfied: pycparser in /usr/lib/python2.7/site-packages (from cffi>=1.4.1->cryptography>=1.1->paramiko>=1.15.0->ncclient>=0.4.7->ydk-models-cisco-ios-xr)
>>> from ydk.models.cisco_ios_xr import Cisco_IOS_XR_ip_static_cfg
>>> from ydk.providers import NetconfServiceProvider
>>> from ydk.services import CRUDService
>>> ncc = NetconfServiceProvider(address='172.27.121.52' , username='root', password='lab', port=830)
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages/ydk/providers/netconf_provider.py", line 69, in __init__
    self._connect()
  File "/auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages/ydk/providers/netconf_provider.py", line 75, in _connect
    self.sp_instance.connect(self.session_config)
  File "/auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages/ydk/providers/_provider_plugin.py", line 296, in connect
    hostkey_verify=False)
  File "/auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages/ncclient/manager.py", line 154, in connect
    return connect_ssh(*args, **kwds)
  File "/auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages/ncclient/manager.py", line 119, in connect_ssh
    session.connect(*args, **kwds)
  File "/auto/cafy_dev/cafykit/exec/lib/python3.4/site-packages/ncclient/transport/ssh.py", line 383, in connect
    raise SSHError("Could not open socket to %s:%s" % (host, port))
ncclient.transport.errors.SSHError: Could not open socket to 172.27.121.52:830
i seen SSH exception , manually i could login
baalagar@exr-idt-ucs.cisco.com%>ssh root@172.27.121.52
Password:
RP/0/RP0/CPU0:ios#
thanks
Bala
jwatters06
I am a network engineer and would like to experiment with yang and netconf on IOS XR. I have followed  the instructions but my install is failing with "Failed building wheel for ydk" Here is some info of my environment and some log messages that might help some one hopefully point me in the right direction which would be great:
Ubuntu (LUbuntu) running in VMWare Fusion on a Mac Book Pro.
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.3 LTS
Release:        16.04
Codename:       xenial
python -V
Python 2.7.12
pip list
beautifulsoup4 (4.4.1)
cffi (1.9.1)
chardet (2.3.0)
cryptography (1.7.1)
defer (1.0.6)
enum34 (1.1.6)
html5lib (0.999)
idna (2.2)
ipaddress (1.0.18)
lxml (3.5.0)
netmiko (1.2.7)
paramiko (2.1.1)
pip (9.0.1)
psutil (3.4.2)
pyasn1 (0.1.9)
pybind11 (2.1.1)
pycparser (2.17)
pycups (1.9.73)
pycurl (7.43.0)
pygobject (3.20.0)
pysmbc (1.0.15.5)
pysqlite (2.7.0)
python-apt (1.1.0b1)
python-debian (0.1.27)
pyxdg (0.25)
PyYAML (3.12)
scp (0.10.2)
setuptools (36.2.7)
six (1.10.0)
wheel (0.29.0)
# portion of output during install
Building wheels for collected packages: ydk
  Running setup.py bdist_wheel for ydk ... error
  Running setup.py clean for ydk
Failed to build ydk
Installing collected packages: ydk, ydk-models-ietf, ydk-models-openconfig, ydk-models-cisco-ios-xr
  Running setup.py install for ydk ... error
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-TS0UEL/ydk/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-M_zvho-record/install-record.txt --compile" failed with error code 1 in /tmp/pip-build-TS0UEL/ydk/
snippet form --log output from pip install command.
running build_ext
    -- The C compiler identification is GNU 5.4.0
    -- The CXX compiler identification is GNU 5.4.0
    -- Check for working C compiler: /usr/bin/cc
    -- Check for working C compiler: /usr/bin/cc -- works
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Detecting C compile features
    -- Detecting C compile features - done
    -- Check for working CXX compiler: /usr/bin/c++
    -- Check for working CXX compiler: /usr/bin/c++ -- works
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- Detecting CXX compile features
    -- Detecting CXX compile features - done
    python library: /usr/lib/python2.7/config-x86_64-linux-gnu/libpython2.7.so
    python include: /usr/include/python2.7
    pybind11 include: /usr/local/include/python2.7;/home/jwatters/.local/include/python2.7
    CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
    Please set them or make sure they are set and tested correctly in the CMake files:
    curl_location
        linked by target "ydk_" in directory /tmp/pip-build-86gcac/ydk
    pcre_location
    ssh_location
    ssh_threads_location
    ydk_location
    -- Configuring incomplete, errors occurred!
Thank you for any tips you can provide.
Jim
The error indicates the system dependencies have not been installed. Can you install these first?
https://github.com/CiscoDevNet/ydk-py
Also please make sure you're using a virtualenv on Mac OSX.
Thank you! I did a clean install of LUbuntu 16.04 I apologize I had used an older link and the linux requirements were a little different then they are now for 0.6.0. I am a little confused that i don't see ydk-models-cisco-ios-xr in my pip list:
pip list
DEPRECATION: The default format will switch to columns in the future. You can use --format=(legacy|columns) (or define a format=(legacy|columns) in your pip.conf under the [list] section) to disable this warning.
chardet (2.3.0)
defer (1.0.6)
pip (9.0.1)
psutil (3.4.2)
pybind11 (2.1.1)
pygobject (3.20.0)
pysqlite (2.7.0)
pyxdg (0.25)
setuptools (36.2.7)
six (1.10.0)
wheel (0.29.0)
ydk (0.6.0)
ydk-models-ietf (0.1.3)
ydk-models-openconfig (0.1.3)
Will try to test a sample with an ASR 9001 that i have in the lab tomorrow.
Jim
Hi Jim,
Culd you please share the outcome of your testing ? I am doing the same testing on IOS-XR platforms and I am facing some issues with NETCONF and YANG.
I have installed all the dependencies mentioned below.
apt-get install libcurl4-openssl-dev libpcre3-dev libssh-dev libxml2-dev libxslt1-dev libtool-bin cmake python3-dev python-dev
My ubuntu version:
root@frettay:/home/ytoolnew/ytool/v# lsb_release -a
Description:    Ubuntu 14.04.5 LTS
Release:        14.04
Codename:       trusty
When i tried to install ydk from source in virtual environment i am getting cmake error as below.
(ydk) root@frettay:/home/ytoolnew/ytool/v/bin/ydk/ydk-py/core# pip install dist/ydk*.gz
Processing ./dist/ydk-0.6.0.tar.gz
Requirement already satisfied: pybind11>=2.1.1 in ./ydk/lib/python2.7/site-packages (from ydk==0.6.0)
  Complete output from command /home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-OGc57f-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpP97MKNpip-wheel- --python-tag cp27:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-i686-2.7
  creating build/lib.linux-i686-2.7/ydk
  copying ydk/exthook.py -> build/lib.linux-i686-2.7/ydk
  copying ydk/__init__.py -> build/lib.linux-i686-2.7/ydk
  creating build/lib.linux-i686-2.7/ydk/entity_utils
  copying ydk/entity_utils/__init__.py -> build/lib.linux-i686-2.7/ydk/entity_utils
  creating build/lib.linux-i686-2.7/ydk/models
  copying ydk/models/__init__.py -> build/lib.linux-i686-2.7/ydk/models
  creating build/lib.linux-i686-2.7/ydk/path
  copying ydk/path/__init__.py -> build/lib.linux-i686-2.7/ydk/path
  creating build/lib.linux-i686-2.7/ydk/providers
  copying ydk/providers/codec_provider.py -> build/lib.linux-i686-2.7/ydk/providers
  copying ydk/providers/__init__.py -> build/lib.linux-i686-2.7/ydk/providers
  creating build/lib.linux-i686-2.7/ydk/errors
  copying ydk/errors/error_handler.py -> build/lib.linux-i686-2.7/ydk/errors
  copying ydk/errors/__init__.py -> build/lib.linux-i686-2.7/ydk/errors
  creating build/lib.linux-i686-2.7/ydk/types
  copying ydk/types/py_types.py -> build/lib.linux-i686-2.7/ydk/types
  copying ydk/types/__init__.py -> build/lib.linux-i686-2.7/ydk/types
  creating build/lib.linux-i686-2.7/ydk/logging
  copying ydk/logging/__init__.py -> build/lib.linux-i686-2.7/ydk/logging
  creating build/lib.linux-i686-2.7/ydk/filters
  copying ydk/filters/__init__.py -> build/lib.linux-i686-2.7/ydk/filters
  creating build/lib.linux-i686-2.7/ydk/services
  copying ydk/services/executor_service.py -> build/lib.linux-i686-2.7/ydk/services
  copying ydk/services/crud_service.py -> build/lib.linux-i686-2.7/ydk/services
  copying ydk/services/netconf_service.py -> build/lib.linux-i686-2.7/ydk/services
  copying ydk/services/codec_service.py -> build/lib.linux-i686-2.7/ydk/services
  copying ydk/services/__init__.py -> build/lib.linux-i686-2.7/ydk/services
  creating build/lib.linux-i686-2.7/ydk/ext
  copying ydk/ext/__init__.py -> build/lib.linux-i686-2.7/ydk/ext
  running build_ext
  -- The C compiler identification is GNU 4.8.4
  -- The CXX compiler identification is GNU 4.8.4
  python library: libpython2.7.so
  python include: /usr/local/include/python2.7
  pybind11 include: /home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/include/site/python2.7;/home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/include/site/python2.7
  ydk_location
      linked by target "ydk_" in directory /tmp/pip-OGc57f-build
  See also "/tmp/pip-OGc57f-build/build/temp.linux-i686-2.7/CMakeFiles/CMakeOutput.log".
    File "<string>", line 1, in <module>
    File "/tmp/pip-OGc57f-build/setup.py", line 157, in <module>
      zip_safe=False,
    File "/usr/local/lib/python2.7/distutils/core.py", line 151, in setup
      dist.run_commands()
    File "/usr/local/lib/python2.7/distutils/dist.py", line 953, in run_commands
      self.run_command(cmd)
    File "/usr/local/lib/python2.7/distutils/dist.py", line 972, in run_command
      cmd_obj.run()
    File "/home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/lib/python2.7/site-packages/wheel/bdist_wheel.py", line 204, in run
      self.run_command('build')
    File "/usr/local/lib/python2.7/distutils/cmd.py", line 326, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "/usr/local/lib/python2.7/distutils/command/build.py", line 127, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "/tmp/pip-OGc57f-build/setup.py", line 69, in run
      self.build_extension(ext)
    File "/tmp/pip-OGc57f-build/setup.py", line 93, in build_extension
      subprocess.check_call(['cmake', ext.sourcedir] + cmake_args, cwd=self.build_temp)
    File "/usr/local/lib/python2.7/subprocess.py", line 540, in check_call
      raise CalledProcessError(retcode, cmd)
  subprocess.CalledProcessError: Command '['cmake', '/tmp/pip-OGc57f-build', '-DCMAKE_LIBRARY_OUTPUT_DIRECTORY=/tmp/pip-OGc57f-build/build/lib.linux-i686-2.7', '-DPYBIND11_INCLUDE=/home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/include/site/python2.7;/home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/include/site/python2.7', '-DPYTHON_LIBRARY=libpython2.7.so', '-DPYTHON_INCLUDE=/usr/local/include/python2.7', '-DCMAKE_BUILD_TYPE=Release']' returned non-zero exit status 1
Failed to build ydk
    Complete output from command /home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-OGc57f-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-QWoWnc-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/include/site/python2.7/ydk:
    running install
    running build
    running build_py
    creating build
    running build_ext
    ydk_location
        zip_safe=False,
        dist.run_commands()
        cmd_obj.run()
      File "/home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/lib/python2.7/site-packages/setuptools/command/install.py", line 61, in run
        return orig.install.run(self)
      File "/usr/local/lib/python2.7/distutils/command/install.py", line 563, in run
        cmd_obj.run()
        cmd_obj.run()
Command "/home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-OGc57f-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-QWoWnc-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/ytoolnew/ytool/v/bin/ydk/ydk-py/core/ydk/include/site/python2.7/ydk" failed with error code 1 in /tmp/pip-OGc57f
Note: Even tried with quick install of ydk and facing the same issue.
