Bookmark
Subscribe
2693
UCS Director 4.1 - Ldap Integration
creviscrevis
Hi Guys,
I need a help , because when i configure ldap integration, UCS Director see a restricted three of my Active Directory and in the attach we can see it I need see others all organizational units, could you please help me ?
rekkrish
Level 4
Level 4
Here are the troubleshooting steps
· The respective domain name abc.com has to resolve from UCSD Appliance
· If the server name is being referring as FQDN then the same name should be resolve from UCSD appliance
· Make sure the name resolution of the respective domain & server resolves to correct IP address and port 389 should be open between UCSD & Domain Controller
· Inframgr logs will show more information about error to troubleshoot the issue more.
Rekha Krishna
Hi Rekha,
I saw the configuration and it´s ok
But Search DN is only this below :
Thanks in advance !
Cleverson Silva
ISU - DC Products - EMC
Capgemini | Brasil
Tel.: +55 11 4196-0665 | Mob.: +55 11 98365-9721
cleverson.silva@capgemini.com<mailto:marcos.a.lima@capgemini.com> // http://br.capgemini.com<http://br.capgemini.com/>
Alameda Araguaia, Nº 2.096 – 3° andar
De: Rekha Krishna
Enviada em: quarta-feira, 16 de julho de 2014 16:03
Para: Cleverson Luis Marques da Silva
Assunto: Re: - UCS Director 4.1 - Ldap Integration
Cisco Communities <https://communities.cisco.com/>
reply from Rekha Krishna<https://communities.cisco.com/people/rekkrish> in Technology > Data Center & Cloud > Unified Computing System (UCS) - View the full discussion<https://communities.cisco.com/message/158655#158655>
Damien Gouju
There have been a lot of LDAP improvement in the 5.0 release, it may also help!
Hello dgoju,
In my team, we had unsuccessful attempt to integrate with Zimbra LDAP on UCSD version 4.1. I must admit that our LDAP tree is very custom, but we can't change it. However, my onderstanding (based on NullPointerExceptions in UCSD logs) was that LDAP integration feature was only playground and basic implementation for something that needs to become more serious in later releases.
Currently we plan upgrade from 4.1.0.3A to 5.2, and it should be smooth, but I am really interested to find out if this could bring us improvements and should we try to integrate with LDAP once again.
Kind Regards
Cisco UCS X-Series Energy Efficiency Offer
