Orf Gelbrich
Task NameIModify NetApp Quotascreate a data store in UCSD and add it to a Data Store cluster
Descriptioncreate a data store in UCSD and add it to a Data Store cluster
Prerequisites
  1. Tested on 5.2.0.2
CategoryWorkflow (and tasks)
ComponentsCloned and modified the task “Associate LUN as Datastore”.
The output field as “dsIdentity”  can be mapped to “Add Datastore to Datastore Cluster”  task
  8. Click "Submit".
  9. A new folder should appear in "Policies-->Orchestration" that contains the imported workflow.
Thanks goes out to Abhilash Pujari .
