Orf Gelbrich
Task NameCreating a NEXUS Account in UCSD
Description
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Thank you Tejeswar Sahu for providing this.
The custom task and task to import:
The workflow:
The workflow inputs:
The custom workflow inputs:
The script:
importPackage(java.lang);
importPackage(java.util);
importPackage(com.cloupia.lib.cIaaS.network.model);//DeviceCredential
importPackage(com.cloupia.feature.networkController.model);//NetworkPersistenceUtil
importPackage(java.util.regex);
importPackage(java.net);
importPackage(com.cloupia.service.cIM.inframgr);//InfrastructureDataUtil
var podName = input.pod;
var deviceIP = input.ip
var protocol = input.protocol;
var port = input.port;
var login = input.login;
var password = input.password;
var deviceCreds;
function addNetworkElementOfCiscoNexusType()
logger.addInfo(":"+podName+":"+deviceIP+":"+protocol+":"+port+":"+login+":"+password+":");
createDeviceCredentialObject();
validateInputs();
/*var deviceCreds = new DeviceCredential();
deviceCreds.setDatacenter(podName);
//DeviceCategoryLOVProvider.CATEGORY_NXOS_DEVICE_ID = "nxos"
deviceCreds.setDeviceCategory(DeviceCategoryLOVProvider.CATEGORY_NXOS_DEVICE_ID);
deviceCreds.setDeviceIp(deviceIP);
deviceCreds.setProtocol(protocol);
deviceCreds.setPort(port);
deviceCreds.setLogin(login);
deviceCreds.setPassword(password);*/
NetworkPersistenceUtil.addDeviceCredential(deviceCreds);
function validateDeviceIP(){
var regex = "^(?:(?:25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.){3}(?:25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)$";
var pattern = Pattern.compile(regex);
var matcher =  pattern.matcher(deviceIP);
   if(matcher.matches() == false) {
   logger.addError("Ip Address :" +deviceIP+ ": is of invalid format.Please provide valid Ip address as input.");
   ctxt.setFailed("input DeviceIP validation failed");
   ctxt.exit();
   } else {
   logger.addInfo("input Device IP address validation passed for:" + deviceIP);
function isDeviceIPAlreadyUsed(){
var isUsed = NetworkPersistenceUtil.isDeviceIPUsed(deviceIP,podName);
if(isUsed){
logger.addError("The IP Address :" + deviceIP + ": is already used in the datacenter :" + podName);
ctxt.setFailed("The IP Address is already used.");
   ctxt.exit();
function isDeviceReachable(){
var ipAddr = InetAddress.getByName(deviceIP);
        var isReachable = ipAddr.isReachable(30000);
        logger.addInfo("isDeviceReachable:"+isReachable);
  if(!isReachable){
  logger.addError("The device IP:"+deviceIP+" is not reachable.");
  ctxt.setFailed("The device IP is not reachable.");
   ctxt.exit();
function isValidLoginOrPassword(){
var errMsg = new StringBuffer("");
var deviceTypeNumeric = DeviceCategoryLOVProvider.DeviceTypeMp.get(DeviceCategoryLOVProvider.CATEGORY_NXOS_DEVICE_ID);
var validConnection = InfrastructureDataUtil.isValidNetworkDeviceForDC(deviceCreds, deviceTypeNumeric, DeviceCategoryLOVProvider.CATEGORY_NXOS_DEVICE_ID, errMsg, true, true);
if(!validConnection){
logger.addError("Invalid login or password:"+errMsg);
ctxt.setFailed("Invalid login or password");
ctxt.exit();
function validateInputs(){
validateDeviceIP();
isDeviceReachable();
isValidLoginOrPassword();
isDeviceIPAlreadyUsed();
logger.addInfo("Validation got successful.");
function createDeviceCredentialObject(){
addNetworkElementOfCiscoNexusType();
