rsivapra
Community Member
Task Name
Get Tenant Onboarding IP Values
Description
This custom task
  is designed for the workflow “FlexPod Tenant Onboarding with Secure Datastore”.
This task will
  fetch the numeric ID of the group created in the workflow and use it to
  construct an IP schema for the Tenant's SVM logical interface and VMkernel
  ports.  These connections will be used
  for the Tenant's private NFS datastore.
Prerequisites
Category
Custom Tasks
Components
UCSD 4.1.x.x
User Inputs
  1. Group ID
Output
LIF IP for NetApp SVM
VMK IP POOL for VMK interfaces
NFS_CLIENT_SPEC for NFS client
  export specification
Instructions
for Use:
  1. Download the attached .ZIP file below to your computer.
    *Remember the location of the saved file on your computer.
  3. Log in to UCS Director as a user that has "system-admin"
    privileges.
  4. Navigate to "Policies-->Orchestration" and click on
    "Import".
  5. Click "Browse" and navigate to the location on your
    computer where the .WFD file resides. Choose the .WFD file and click "Open".
  6. Click "Upload" and then "OK" once the file
    upload is completed. Then click "Next".
  7. Click the "Select" button next to "Import
    Workflows". Click the "Check All" button to check all checkboxes
    and then the "Select" button.
  8. Click "Submit".
  9. A new folder should appear in "Policies-->Orchestration"
    that contains the imported workflow. You will now need to update the included
    tasks with information about the specific environment.
