Orf Gelbrich
Task NameAdd a VM Kernel port group with static IP
Description
Prerequisites
Minimum UCSD version: 5.4.0.0
CategoryCustom task
Components
User Inputs
User Output
  8. Click "Submit".
A big thank you goes to:  Ryan Criss and Abhishek Bhardwaj
The workflow file contains a custom workflow task:
The Task Comments:
The Task Input:
The task output:
The Code:
importPackage(java.util);
importPackage(java.lang);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(com.cloupia.service.cIM.inframgr.profiles);
importPackage(com.cloupia.service.cIM.inframgr.forms.wizard);
importPackage(com.cloupia.lib.cIaaS.vmware);
// Author: Ryan Criss (rcriss@cisco.com)
// Workflow Task Name: Add VMkernel Port to DVS with Static IP
// Version: 1.0
// Description:
// This custom task adds a VMkernel Port to the DVS with a Static IP
// Inputs:
// hostNode: The ESX host you would like to add a VMkernel port to
// dvPortGroupName: The DV port group used for the new VMkernel Port
// ipAddress: The IP address of the new VMkernel Port
// subnetMask: The subnet mask of the new VMkernel Port
// mtuSize: The MTU size of the new VMkernel Port
// vmotion: Is this new VMkernel Port enabled for vMotion
// Outputs:
// OUTPUT_VMWARE_HOST_NODE_IDENTITY
// OUTPUT_VMWARE_DV_PORT_GROUP_IDENTITY
// OUTPUT_IP_POOL_POLICY_ID
// OUTPUT_DV_PORT_GROUP_NAME
// OUTPUT_STATIC_POOL_IP
// OUTPUT_STATIC_POOL_IPS_ALLOCATED
// OUTPUT_MTU_SIZE
//                                 ### FUNCTIONS ###
// None
//                                 ### MAIN PROGRAM ###
// Setup Inputs
var hostNode = input.hostNode;
var dvPortGroupName = input.dvPortGroupName;
var ipAddress = input.ipAddress;
var subnetMask = input.subnetMask;
var mtuSize = input.mtuSize;
var vmotion = input.vmotion;
// Create Temporary IP Pool
var policyName = ipAddress;
var policyDescription = "Temporary policy for " + ipAddress;
var staticIPPool = ipAddress;
var pools = new PrivateCloudStaticIPPool();
pools.setStaticIpPool(staticIPPool);
pools.setSubnetMask(subnetMask);
var poolsList = new FormManagedList();
poolsList.getList().add(pools);
var policy = new PrivateCloudStaticIPPoolPolicy();
policy.setPolicyName(policyName);
policy.setPolicyDescription(policyDescription);
policy.setStaticIPPools(poolsList);
var def= new StaticIPPoolDef();
def.setIpPools(policy.getStaticIPPools().getList());
var defStr = VMWareUtils.getPrivateCloudStaticIPPoolDefStr(def);
policy.setIpPoolInfoStr(defStr);
var result = InfraPersistenceUtil.persistPrivateCloudStaticIPPoolPolicy(policy);
if(result){
  logger.addInfo("Static IP Pool Policy  "+policyName+"  created successfully.");
  var policyObj = InfraPersistenceUtil.getPrivateCloudStaticIPPoolPolicy(policyName);
  var policyId = policyObj.getPolicyId();
  logger.addInfo("Policy Id: "+policyId);
  var staticIpPolicyIdentity = policyId + "@" + policyName;
} else {
  throw new Exception("Static IP Pool policy "+policyName+"  not created.");
// Create VMKernel Port on DVS
var task = ctxt.createInnerTaskContext("Add VMKernel Port On DVSwitch");
task.setInput("Host Node", hostNode);
task.setInput("DVPortGroup Name", dvPortGroupName);
task.setInput("Network Type", "IPv4");
task.setInput("Select IP Address Type", "1");
task.setInput("Static IP Pool", staticIpPolicyIdentity);
task.setInput("MTU Size", mtuSize);
task.setInput("Enable vMotion", vmotion);
// Now execute the task. If the task fails, then it will throw an exception
task.execute();
// Now copy the outputs of the inner task for use by subsequent tasks
output.OUTPUT_VMWARE_HOST_NODE_IDENTITY = task.getOutput("OUTPUT_VMWARE_HOST_NODE_IDENTITY");
// Type of following output: VMwareDVPortgroupIdentity
output.OUTPUT_VMWARE_DV_PORT_GROUP_IDENTITY = task.getOutput("OUTPUT_VMWARE_DV_PORT_GROUP_IDENTITY");
// Type of following output: VMWareIPPoolPolicy
output.OUTPUT_IP_POOL_POLICY_ID = task.getOutput("OUTPUT_IP_POOL_POLICY_ID");
// Type of following output: dvPortGroupName
output.OUTPUT_DV_PORT_GROUP_NAME = task.getOutput("OUTPUT_DV_PORT_GROUP_NAME");
// Type of following output: StaticPoolIP
output.OUTPUT_STATIC_POOL_IP = task.getOutput("OUTPUT_STATIC_POOL_IP");
// Type of following output: gen_text_input
output.OUTPUT_STATIC_POOL_IPS_ALLOCATED = task.getOutput("OUTPUT_STATIC_POOL_IPS_ALLOCATED");
output.OUTPUT_MTU_SIZE = task.getOutput("OUTPUT_MTU_SIZE");
// Delete Temporary IP Pool
try{
  InfraPersistenceUtil.deletePrivateCloudStaticIPPoolPolicy(policyId);
} catch(e){
  logger.addError("Error occurred while deleting the static ip pool policy with id: "+policyId);
  logger.addError(e);
