Orf Gelbrich
Task NameAdding different VLAN names to A and B side of UCSM
Description
Prerequisites
Tested on 5.5
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
VLAN Name
VLAN ID
  8. Click "Submit".
The UCSM output:
The workflow:
Global Input:
Add VLAN Task A
Add VLAN Task B:
Workflow Input:
Execution Log:
Service Request ID: 7610
Workflow Inputs:
- VLAN
- VLANName
- UCSAccount
Jul 06, 2016 17:42:22 UTC Request submitted
Jul 06, 2016 17:42:23 UTC Executing workflow item number 1
Jul 06, 2016 17:42:23 UTC Completed workflow item number 1, with status Completed
Jul 06, 2016 17:42:27 UTC Executing workflow item number 2
Jul 06, 2016 17:42:27 UTC Trigger context executeWorkFlowStep called
Jul 06, 2016 17:42:27 UTC Executing custom action CreateVLAN_UCS_A_B (custom_VLAN CHECK UCSM)
Jul 06, 2016 17:42:27 UTC Executing custom script for VLAN CHECK UCSM
Jul 06, 2016 17:42:30 UTC -------------------------------------
Jul 06, 2016 17:42:30 UTC Iteration 0
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-default
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-default
Jul 06, 2016 17:42:30 UTC NAME default
Jul 06, 2016 17:42:30 UTC ID 1
Jul 06, 2016 17:42:30 UTC Looking for VLAN...............: 501
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 1
Jul 06, 2016 17:42:30 UTC Iteration 1
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/eth-estc/net-default
Jul 06, 2016 17:42:30 UTC DN fabric/eth-estc/net-default
Jul 06, 2016 17:42:30 UTC Iteration 2
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-VLAN_32
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-VLAN_32
Jul 06, 2016 17:42:30 UTC NAME VLAN_32
Jul 06, 2016 17:42:30 UTC ID 32
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 32
Jul 06, 2016 17:42:30 UTC Iteration 3
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-PXE_Boot_Vlan
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-PXE_Boot_Vlan
Jul 06, 2016 17:42:30 UTC NAME PXE_Boot_Vlan
Jul 06, 2016 17:42:30 UTC ID 666
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 666
Jul 06, 2016 17:42:30 UTC Iteration 4
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-703beta
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-703beta
Jul 06, 2016 17:42:30 UTC NAME 703beta
Jul 06, 2016 17:42:30 UTC ID 703
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 703
Jul 06, 2016 17:42:30 UTC Iteration 5
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-708TAMU
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-708TAMU
Jul 06, 2016 17:42:30 UTC NAME 708TAMU
Jul 06, 2016 17:42:30 UTC ID 708
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 708
Jul 06, 2016 17:42:30 UTC Iteration 6
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/eth-estc/net-NimbleA
Jul 06, 2016 17:42:30 UTC DN fabric/eth-estc/net-NimbleA
Jul 06, 2016 17:42:30 UTC NAME NimbleA
Jul 06, 2016 17:42:30 UTC ID 30
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 30
Jul 06, 2016 17:42:30 UTC Iteration 7
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/eth-estc/net-NimbleB
Jul 06, 2016 17:42:30 UTC DN fabric/eth-estc/net-NimbleB
Jul 06, 2016 17:42:30 UTC NAME NimbleB
Jul 06, 2016 17:42:30 UTC ID 31
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 31
Jul 06, 2016 17:42:30 UTC Iteration 8
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-500test
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-500test
Jul 06, 2016 17:42:30 UTC NAME 500test
Jul 06, 2016 17:42:30 UTC ID 500
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 500
Jul 06, 2016 17:42:30 UTC Iteration 9
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-803testbaylo
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-803testbaylo
Jul 06, 2016 17:42:30 UTC NAME 803testbaylo
Jul 06, 2016 17:42:30 UTC ID 803
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 803
Jul 06, 2016 17:42:30 UTC Iteration 10
Jul 06, 2016 17:42:30 UTC ID DallasUCSM;fabric/lan/net-633DSW
Jul 06, 2016 17:42:30 UTC DN fabric/lan/net-633DSW
Jul 06, 2016 17:42:30 UTC NAME 633DSW
Jul 06, 2016 17:42:30 UTC ID 633
Jul 06, 2016 17:42:30 UTC Found VLAN...............: 633
Jul 06, 2016 17:42:30 UTC Processing output: ReturnStatus
Jul 06, 2016 17:42:31 UTC Task #2 (CreateVLAN_UCS_A_B (custom_VLAN CHECK UCSM)) completed successfully in 4 seconds
Jul 06, 2016 17:42:31 UTC Input/Output values for Task #2 (CreateVLAN_UCS_A_B (custom_VLAN CHECK UCSM)):
Jul 06, 2016 17:42:31 UTC [Mapped Input: UCSMAccount = DallasUCSM]
Jul 06, 2016 17:42:31 UTC [Mapped Input: UCSMVLAN = 501]
Jul 06, 2016 17:42:31 UTC [Output: ReturnStatus = 0]
Jul 06, 2016 17:42:31 UTC Completed workflow item number 2, with status Completed
Jul 06, 2016 17:42:37 UTC Executing workflow item number 3
Jul 06, 2016 17:42:37 UTC Trigger context executeWorkFlowStep called
Jul 06, 2016 17:42:37 UTC Executing custom action CreateVLAN_UCS_A_B (Add VLAN)
Jul 06, 2016 17:42:41 UTC VLAN created
Jul 06, 2016 17:42:45 UTC Task #3 (CreateVLAN_UCS_A_B (Add VLAN)) completed successfully in 7 seconds
Jul 06, 2016 17:42:45 UTC Input/Output values for Task #3 (CreateVLAN_UCS_A_B (Add VLAN)):
Jul 06, 2016 17:42:45 UTC [Template Input:VLAN Name = A-${VLANName}]
Jul 06, 2016 17:42:45 UTC [Resolved Template Input: VLAN Name = A-WEBTier501]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN Name = A-WEBTier501]
Jul 06, 2016 17:42:45 UTC [Mapped Input: Account Name = DallasUCSM]
Jul 06, 2016 17:42:45 UTC [Local Input: Physical Infrastructure = true]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN Type = A]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN ID(Common/Global) = ]
Jul 06, 2016 17:42:45 UTC [Mapped Input: VLAN ID (Fabric A) = 501]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN ID (Fabric B) = ]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN A = null]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN ID A(Both Fabrics Configured Differently) = ]
Jul 06, 2016 17:42:45 UTC [Local Input: Sharing = None]
Jul 06, 2016 17:42:45 UTC [Local Input: Primary VLAN = ]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN B = null]
Jul 06, 2016 17:42:45 UTC [Local Input: VLAN ID B(Both Fabrics Configured Differently) = ]
Jul 06, 2016 17:42:45 UTC [Local Input: Virtual Infrastructure = false]
Jul 06, 2016 17:42:45 UTC [Local Input: Organizations = ]
Jul 06, 2016 17:42:45 UTC [Local Input: Service Profiles = ]
Jul 06, 2016 17:42:45 UTC [Local Input: Service Profiles Templates = ]
Jul 06, 2016 17:42:45 UTC [Local Input: vNIC Templates = ]
Jul 06, 2016 17:42:45 UTC [Output: OUTPUT_VLAN_IDENTITY1 = DallasUCSM;fabric/lan/A/net-A-WEBTier501]
Jul 06, 2016 17:42:45 UTC [Output: OUTPUT_VLAN_ID1 = 501]
Jul 06, 2016 17:42:45 UTC [Output: OUTPUT_VLAN_IDENTITY2 = ]
Jul 06, 2016 17:42:45 UTC [Output: OUTPUT_VLAN_ID2 = ]
Jul 06, 2016 17:42:45 UTC Completed workflow item number 3, with status Completed
Jul 06, 2016 17:42:47 UTC Executing workflow item number 4
Jul 06, 2016 17:42:47 UTC Trigger context executeWorkFlowStep called
Jul 06, 2016 17:42:47 UTC Executing custom action CreateVLAN_UCS_A_B (Add VLAN)
Jul 06, 2016 17:42:48 UTC Executing custom action CreateVLAN_UCS_A_B (Add VLAN)
Jul 06, 2016 17:42:52 UTC VLAN created
Jul 06, 2016 17:42:56 UTC Task #4 (CreateVLAN_UCS_A_B (Add VLAN)) completed successfully in 8 seconds
Jul 06, 2016 17:42:56 UTC Input/Output values for Task #4 (CreateVLAN_UCS_A_B (Add VLAN)):
Jul 06, 2016 17:42:56 UTC [Template Input:VLAN Name = B-${VLANName}]
Jul 06, 2016 17:42:56 UTC [Resolved Template Input: VLAN Name = B-WEBTier501]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN Name = B-WEBTier501]
Jul 06, 2016 17:42:56 UTC [Mapped Input: Account Name = DallasUCSM]
Jul 06, 2016 17:42:56 UTC [Local Input: Physical Infrastructure = true]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN Type = B]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN ID(Common/Global) = ]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN ID (Fabric A) = ]
Jul 06, 2016 17:42:56 UTC [Mapped Input: VLAN ID (Fabric B) = 501]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN A = null]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN ID A(Both Fabrics Configured Differently) = ]
Jul 06, 2016 17:42:56 UTC [Local Input: Sharing = None]
Jul 06, 2016 17:42:56 UTC [Local Input: Primary VLAN = ]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN B = null]
Jul 06, 2016 17:42:56 UTC [Local Input: VLAN ID B(Both Fabrics Configured Differently) = ]
Jul 06, 2016 17:42:56 UTC [Local Input: Virtual Infrastructure = false]
Jul 06, 2016 17:42:56 UTC [Local Input: Organizations = ]
Jul 06, 2016 17:42:56 UTC [Local Input: Service Profiles = ]
Jul 06, 2016 17:42:56 UTC [Local Input: Service Profiles Templates = ]
Jul 06, 2016 17:42:56 UTC [Local Input: vNIC Templates = ]
Jul 06, 2016 17:42:56 UTC [Output: OUTPUT_VLAN_IDENTITY1 = DallasUCSM;fabric/lan/B/net-B-WEBTier501]
Jul 06, 2016 17:42:56 UTC [Output: OUTPUT_VLAN_ID1 = 501]
Jul 06, 2016 17:42:56 UTC [Output: OUTPUT_VLAN_IDENTITY2 = ]
Jul 06, 2016 17:42:56 UTC [Output: OUTPUT_VLAN_ID2 = ]
Jul 06, 2016 17:42:56 UTC Completed workflow item number 4, with status Completed
Jul 06, 2016 17:42:58 UTC Executing workflow item number 5
Jul 06, 2016 17:42:58 UTC Trigger context executeWorkFlowStep called
Jul 06, 2016 17:42:58 UTC Executing custom action CreateVLAN_UCS_A_B (Send Email)
Jul 06, 2016 17:43:01 UTC Sending email to ogelbric@cisco.com, with Subject VLAN 7610 Created
Jul 06, 2016 17:43:02 UTC Task #5 (CreateVLAN_UCS_A_B (Send Email)) completed successfully in 3 seconds
Jul 06, 2016 17:43:02 UTC Input/Output values for Task #5 (CreateVLAN_UCS_A_B (Send Email)):
Jul 06, 2016 17:43:02 UTC [Template Input:E-mail Addresses = ${SUBMITTER_EMAIL}]
Jul 06, 2016 17:43:02 UTC [Resolved Template Input: E-mail Addresses = ogelbric@cisco.com]
Jul 06, 2016 17:43:02 UTC [Local Input: E-mail Addresses = ogelbric@cisco.com]
Jul 06, 2016 17:43:02 UTC [Template Input:Subject = VLAN ${SR_ID} Created]
Jul 06, 2016 17:43:02 UTC [Resolved Template Input: Subject = VLAN 7610 Created]
Jul 06, 2016 17:43:02 UTC [Local Input: Subject = VLAN 7610 Created]
Jul 06, 2016 17:43:02 UTC [Template Input:Body = VLAN Creation ============ Name: ${VLANName} ID: ${VLAN} ]
Jul 06, 2016 17:43:02 UTC [Resolved Template Input: Body = VLAN Creation ============ Name: WEBTier501 ID: 501 ]
Jul 06, 2016 17:43:02 UTC [Local Input: Body = VLAN Creation ============ Name: WEBTier501 ID: 501 ]
Jul 06, 2016 17:43:02 UTC [Output: EMAIL_ADDRESSES = ogelbric@cisco.com]
Jul 06, 2016 17:43:02 UTC Completed workflow item number 5, with status Completed
Jul 06, 2016 17:43:05 UTC Executing workflow item number 6
Jul 06, 2016 17:43:05 UTC Completed workflow item number 6, with status Completed
Workflow Rollback:
