Sabina Al Farah
Task NameUCSD and UCSM HTTP integration Example
Description
  1. Obtain UCSM boot order
Prerequisites
  1. Tested on 5.3
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Custom Workflow Task : GetUCSM_ServiceProfileBootOrder
This task has  4 inputs : uri, username, passwd, serviceprofilename
This task has  4 outputs : vHBA0_P, vHBA0_S, vHBA1_P, vHBA1_S
This task has a Cloupia Script .
The Script does the following
—>Login to UCS-XML-API  using xml over http
—>get session cookie
—>Use the cookie to fetch other details
—>Parse Xml response , get the required output data(wwn)
TEST using Sample Workflow : Get UCSM boot Order
This w/f has 4 inputs associated with admin input ( done for ease of testing … However these inputs can be mapped to the output from prior tasks in any other workflow)
Code Example:
importPackage(java.io);
importPackage(javax.xml.xpath);
importPackage(org.apache.commons.httpclient);
importPackage(org.apache.commons.httpclient.methods);
importPackage(org.xml.sax);
importPackage(com.cloupia.model.cIM);
importPackage(com.cloupia.service.cIM.inframgr);
var UCSM_URI = "UCSM_URI";
var UCSM_Username = "UCSM_Username";
var UCSM_Password = "UCSM_Password";
var UCSM_ServiceProfile = "UCSM_ServiceProfile";
// var url = "http://" + ctxt.getInput(UCSM_URI) + ":80/nuova";
// var username = ctxt.getInput(UCSM_Username);
// var password = ctxt.getInput(UCSM_Password);
// var serviceProfile = ctxt.getInput(UCSM_ServiceProfile);
var url = "http://" + input.UCSM_URI + ":80/nuova";
var username = input.UCSM_Username;
var password = input.UCSM_Password;
var serviceProfile = input.UCSM_ServiceProfile;
var cookie;
var quesryResp;
logger.addInfo("=================BEGIN=================");
logger.addInfo("========LOGIN to UCS XML API========");
doLogin();
logger.addInfo("========UCS Query set context========");
doQueryDN("org-root/ls-" + serviceProfile, false);
logger.addInfo("========UCS Query Fetch Data========");
var responseXML = doQueryDN("org-root/boot-policy-SAN_Boot/storage", true);
logger.addInfo("========LOGOUT frm UCS XML API========");
doLogout();
logger.addInfo("========Parse Response and get data========");
getStorageBootOrder(responseXML);
logger.addInfo("=================END=================");
function doLogin() {
var loginxml = "<aaaLogin inName='" + username + "' inPassword= '" + password + "'></aaaLogin>";
logger.addInfo("loginXML:" + loginxml);
var xml = doPostXML(loginxml);
logger.addInfo("tokenXML:" + xml);
cookie = getXpathData("//aaaLogin/@outCookie", xml);
logger.addInfo("token:" + cookie);
function doLogout() {
var logoutxml = "<aaaLogout inCookie='" + cookie + "'></aaaLogout>";
logger.addInfo("logoutxml:" + logoutxml);
var xml = doPostXML(logoutxml);
logger.addInfo("logoutRespxml:" + xml);
function doQueryDN(queryPath, inHierarchical) {
var queryxml = "<configResolveDn dn='" + queryPath + "' cookie='" + cookie + "' inHierarchical='" + inHierarchical + "'/>";
var xml = doPostXML(queryxml);
logger.addInfo("Result:" + queryPath + ": " + xml);
return xml;
function doQueryChildren(queryPath) {
var queryxml = "<configResolveChildren inDn='" + queryPath + "' cookie='" + cookie + "' inHierarchical='" + inHierarchical + "'/>";
logger.addInfo("Result:" + xml);
function getStorageBootOrder(xml) {
var vHBA0_P = getXpathData("/configResolveDn/outConfig/lsbootStorage[@dn='org-root/boot-policy-SAN_Boot/storage']/lsbootSanImage[@type='primary']/lsbootSanImagePath[@type='primary']/@wwn", xml);
var vHBA0_S = getXpathData("/configResolveDn/outConfig/lsbootStorage[@dn='org-root/boot-policy-SAN_Boot/storage']/lsbootSanImage[@type='primary']/lsbootSanImagePath[@type='secondary']/@wwn", xml);
var vHBA1_P = getXpathData("/configResolveDn/outConfig/lsbootStorage[@dn='org-root/boot-policy-SAN_Boot/storage']/lsbootSanImage[@type='secondary']/lsbootSanImagePath[@type='primary']/@wwn", xml);
var vHBA1_S = getXpathData("/configResolveDn/outConfig/lsbootStorage[@dn='org-root/boot-policy-SAN_Boot/storage']/lsbootSanImage[@type='secondary']/lsbootSanImagePath[@type='secondary']/@wwn", xml);
logger.addInfo("vHBA0_P:" + vHBA0_P);
logger.addInfo("vHBA0_S:" + vHBA0_S);
logger.addInfo("vHBA1_P:" + vHBA1_P);
logger.addInfo("vHBA1_S:" + vHBA1_S);
output.vHBA0_P = vHBA0_P;
output.vHBA0_S = vHBA0_S;
output.vHBA1_P = vHBA1_P;
output.vHBA1_S = vHBA1_S;
// ctxt.setOutputValue("vHBA0_P",vHBA0_P)
function getXpathData(xpathString, xml) {
var xpathFactory = XPathFactory.newInstance();
var xpath = xpathFactory.newXPath();
var source = new InputSource(new StringReader(xml));
try {
var msg = xpath.evaluate(xpathString, source);
return msg;
} catch (e) {
logger.addInfo("ERROR :" + e);
return "";
function doPostXML(data) {
var br = null;
var xml = "";
var httpClient = new HttpClient();
httpClient.getParams().setParameter("http.useragent", "UCSD Script Client");
var httpMethod = new PostMethod(url);
httpMethod.setRequestEntity(new StringRequestEntity(data));
httpMethod.addRequestHeader("Content-Type", "application/xml");
try {
var statuscode = httpClient.executeMethod(httpMethod);
if (statuscode != 200) {
// logger.addError("Error in invocation "+statuscode);
} else {
br = new BufferedReader(new InputStreamReader(httpMethod.getResponseBodyAsStream()));
var readLine = "";
var response = "";
while (((readLine = br.readLine()) != null)) {
response = response + readLine;
xml = response.toString();
} catch (e) {
} finally {
httpMethod.releaseConnection();
if (br != null)
try {
br.close();
} catch (fe) {}
return xml;
