hapresto
Prerequisites
  1. Built on UCSD 5.3
  8. Click "Submit".
With network automation, an area that is critical is the ability to dynamically manage networks/subnets for new projects and applications.  UCS Director already provides the ability to manage much of this, but there are a couple of gaps with the OOB features.  A common set of steps needed when automating the network are:
1)  Get the new Subnet
2)  Identify the Range of IPs to be used for hosts/guests
3)  Build a new Static IP Policy to use for assigning IPs to VMs/hosts
Steps 2 and 3 are difficult with the OOB tasks from UCSD.  Here you'll find 2 new tasks that add these capabilities.
Included in this attachment
1)  Sample Workflow to build a new IP Policy Based on a Subnet
2)  Custom Task to Calculate the IP Range and First/Last available IPs
3)  Custom Task to Create a Static IP Pool Policy with rollback
4)  Custom Task to Return the Prefix for a subnet
A Sample Workflow
Service Request Status
Task Outputs
