Orf Gelbrich
Task NameBlue Cat IP Request
Description
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Many thanks go out to Kevin Chua
The Custom Task at Import:
The Custom Task:
The Custom Input Variables:
The Custom Output Variables:
The before Marshal:
(generating the LoV for the Credential Policy that must be chosen during the task configuration in the workflow.)
The Code in the Custom Task:
importPackage(java.util);
importPackage(java.lang);
importPackage(java.io);
importPackage(org.w3c.dom);
importPackage(com.cloupia.lib.util);
importPackage(com.cloupia.model.cIM);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(com.cloupia.sysmgr.upgrade.util);
importPackage(com.cloupia.fw.objstore);
importPackage(com.cloupia.lib.util.easytrust);
importPackage(org.apache.commons.httpclient);
importPackage(org.apache.commons.httpclient.cookie);
importPackage(org.apache.commons.httpclient.methods);
importPackage(org.apache.commons.httpclient.auth);
importPackage(org.apache.commons.httpclient.protocol);
importClass(org.apache.commons.httpclient.protocol.SecureProtocolSocketFactory);
importPackage(com.cloupia.lib.connector.account);
importPackage(com.cloupia.lib.connector.account.credential);
//             Author: Kevin Chua (kevchua@cisco.com)
// Workflow Task Name: Bluecat Get IP and Hostname
//            Version: 1.0
//      Description: Script performs Authentication to Bluecat Address Manager (BAM) API
//                     where the authentication cookie is stored for subsequent BAM API
//                     calls to find the next available IP4 Address and Hostname
//           Bluecat: Bluecat Address Manager v4.1.0
//             Inputs: bluecatUser ;BAM API username
//                        bluecatPassword ;BAM API password
//                        BluecatIP                ;BAM API FQDN
//                        BluecatTransport  ;http or https
//                        GenCoNetwork                 ;P or N
//                        GenCoHostOSType            ;L or W
//                        entityId                          ;Admin Input Value -> entityId of a BAM Object
//                        dnsViewOID                    ;Require Object ID of the DNS View
//                        prodTagName                  ;Tag name for Production
//                        prodTagNameEntityID       ;Tag name Object ID
//                        nonprodTagName             ;Tag name for Non-Production
//                        nonprodTagNameEntityID  ;Tag name Object ID
//            Outputs: CIDR ;Returns IP4 Network range
//                     nextIP4Address ;Returns Next Available IP4 Address in IP4 Network
//                     gateway ;Returns Gateway IP4 Address
//                     netmask ;Returns netmask
//                     nextHostname ;Returns Next Available Hostname
//                     nextFQDN ;Returns Fully Qualified Next Available Hostname
//                     nextHostNumber             ;Returns Number in the Next Available Hostname
//                                 ### FUNCTIONS ###
//Get the Credentials from the Credentials policy.
function getAccount(accountName) {
  logger.addInfo("Looking for the following account: " + accountName);
  var account = PersistenceUtil.getCredentialPolicyByName(accountName);
  if (account != null) {
  logger.addInfo("Account: " + accountName + " found.");
  return account;
  } else {
  logger.addError("Account: " + accountName + " NOT found.");
  ctxt.setFailed("No Account found with name: " + accountName);
//    Created By: Russ Whitear (rwhitear@cisco.com)
//    Updated By: Kevin Chua (kevchua@cisco.com)
// Function Name: httpRequest()
//       Version: 1.2
//   Description: HTTP Request function - httpRequest.
//                The httpClient functionality more object like in order to
//                make cloupia scripts more readable when making many/multiple HTTP/HTTPS
//                requests within a single script.
//  Modification: Additional Content-Type for XML added (i.e., text/xml)
//                Execute method customized with additional logic based on the Bluecat API
//                name. This is required since the Login event will receive a Cookie that
//                must be added into the HTTP header during subsequent Bluecat API calls
//      Usage: 1. var request = new httpRequest();                   // Create new object.
//             2. request.setup("192.168.10.10","https","admin","cisco123");      // SSL.
//          or:   request.setup("192.168.10.10","http","admin","cisco123");       // HTTP.
//          or:   request.setup("192.168.10.10","https");           // SSL, no basicAuth.
//          or:   request.setup("192.168.10.10","http");            // HTTP, no basicAuth.
//             3. request.getRequest("/");                    // HTTP GET (URI).
//          or:   request.postRequest("/","some body text");  // HTTP POST (URI,BodyText).
//          or:   request.deleteRequest("/");                 // HTTP DELETE (URI).
//  (optional) 4. request.contentType("json");            // Add Content-Type HTTP header.
//          or:   request.contentType("xmla");            // application/xml
//          or:   request.contentType("xmlt");            // text/xml
//  (optional) 5. request.addHeader("X-Cloupia-Request-Key","1234567890");  // Any Header.
//             6. var statusCode = request.execute(apiName);                // Send request.
//             7. var response = request.getResponse("asString");   // Response as string.
//          or:   var response = request.getResponse("asStream");   // Response as stream.
//             8. request.disconnect();                             // Release connection.
var httpRequest = function () {};
httpRequest.prototype.setup = function(serverIp, transport, username, password) {
  this.serverIp = serverIp;
  this.transport = transport;
  this.username = username;
  this.password = password;
  this.httpClient = new HttpClient();
  // Decide whether to create an HTTP or HTTPS connection based up 'transport'.
  if( this.transport == "https" ) {
  this.factory = new SecureProtocolSocketFactory() {
  createSocket : function(socket, host, port, autoClose) {
  this.fact = new com.cloupia.lib.util.easytrust.EasySSLProtocolSocketFactory();
  this.sock = this.fact.createSocket(socket, host, port, autoClose);
  this.sock.setEnabledCipherSuites([
  "SSL_RSA_WITH_RC4_128_MD5",
  "SSL_RSA_WITH_RC4_128_SHA",
  "TLS_RSA_WITH_AES_128_CBC_SHA",
  "TLS_DHE_RSA_WITH_AES_128_CBC_SHA",
  "TLS_DHE_DSS_WITH_AES_128_CBC_SHA",
  "SSL_RSA_WITH_3DES_EDE_CBC_SHA",
  "SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA",
  "SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA",
  "SSL_RSA_WITH_DES_CBC_SHA",
  "SSL_DHE_RSA_WITH_DES_CBC_SHA",
  "SSL_DHE_DSS_WITH_DES_CBC_SHA",
  "SSL_RSA_EXPORT_WITH_RC4_40_MD5",
  "SSL_RSA_EXPORT_WITH_DES40_CBC_SHA",
  "SSL_DHE_RSA_EXPORT_WITH_DES40_CBC_SHA",
  "SSL_DHE_DSS_EXPORT_WITH_DES40_CBC_SHA"]);
  return this.sock;
  this.easyhttps = new Protocol(
  "https",
  this.factory,
  443);
  this.httpClient.getHostConfiguration().setHost(this.serverIp,443,this.easyhttps);
  } else {
  // Create new HTTP connection.
  this.httpClient.getHostConfiguration().setHost(this.serverIp, 80, "http");
  this.httpClient.getParams().setCookiePolicy("default");
  // If username and password supplied, then use basicAuth.
  if( this.username && this.password ) {
  this.httpClient.getParams().setAuthenticationPreemptive(true);
  this.defaultcreds = new UsernamePasswordCredentials(this.username, this.password);
  this.httpClient.getState().setCredentials(new AuthScope(this.serverIp, -1, null), this.defaultcreds);
httpRequest.prototype.contentType = function(contentType) {
  this.contentType = contentType;
  // Added Content-Type = text/xml for Bluecat SOAP API
  this.contentTypes = [
  ["xmlt","text/xml"],
  ["xmla","application/xml"],
  ["json","application/json"]
  for( this.i=0; this.i<this.contentTypes.length; this.i++)
  if(this.contentTypes[this.i][0] == this.contentType)
  this.httpMethod.addRequestHeader("Content-Type", this.contentTypes[this.i][1]);
httpRequest.prototype.addHeader = function(headerName,headerValue) {
  this.headerName = String(headerName);
  this.headerValue = String(headerValue);
  this.httpMethod.addRequestHeader(this.headerName, this.headerValue);
httpRequest.prototype.execute = function(apiName) {
  //Pass in Bluecat API Name to handle first time processing on gathering the Cookie Info
  this.apiName = apiName;
  // Connection:close is hard coded here in order to ensure that the TCP connection
  // gets torn down immediately after the request. Comment this line out if you wish to
  // experiment with HTTP persistence.
  this.httpMethod.addRequestHeader("Connection", "keep-alive");
  this.httpClient.executeMethod(this.httpMethod);
  if (this.apiName == "login") {
  // Need to capture the Cookie (JSSESSIONID) generated with the Bluecat Login API
  var cookies = this.httpClient.getState().getCookies();
  var cookie = String(cookies[0]);
  //logger.addInfo("Value: "+cookie);
  //logger.addInfo("typeof: " +typeof cookie);
  var cookievalue = cookie.substring(parseInt(cookie.indexOf("="))+1);
  //logger.addInfo(cookievalue);
  // Retrieve status code.
  this.statusCode = this.httpMethod.getStatusCode();
  return [this.statusCode, cookievalue];
  } else {
  return this.statusCode;
httpRequest.prototype.getRequest = function(uri) {
  this.uri = uri;
  // Get request.
  this.httpMethod = new GetMethod(this.uri);
httpRequest.prototype.postRequest = function(uri,bodytext) {
  this.uri = uri;
  this.bodytext = bodytext;
  // POST Request.
  this.httpMethod = new PostMethod(this.uri);
  this.httpMethod.setRequestEntity(new StringRequestEntity(this.bodytext));
httpRequest.prototype.getResponse = function(asType) {
  this.asType = asType;
  if( this.asType == "asStream" )
  return this.httpMethod.getResponseBodyAsStream();
  else
  return this.httpMethod.getResponseBodyAsString();
httpRequest.prototype.deleteRequest = function(uri) {
  this.uri = uri;
  // Get request.
  this.httpMethod = new DeleteMethod(this.uri);
httpRequest.prototype.disconnect = function() {
  this.httpMethod.releaseConnection();
//    Created By: Kevin Chua (kevchua@cisco.com)
// Function Name: getCount()
//       Version: 1.0
//   Description: Count the number of occurrences for an XML tag within the BAM API
//                Response message
//        Inputs: str ;Result String to search
//                d   ;Patter to search for
//       Outputs: #   ;Returns number of times "d" pattern found in str
function getCount(str,d) {
    return str.split("<"+d+">").length - 1;
// Function Name: parseIP4NetworkResult()
//       Version: 1.0
//   Description: Parse the BAM API response message for an IP4 Network to split the string
//                into IP4 Network w/CIDR, Gateway, and determine the netmask
//        Inputs: strResult ;Result string to parse
//       Outputs: entityID  ;Returns the Object/Entity ID for the IP4 Network
//                CIDR ;Returns IP4 Network range
function parseIP4NetworkResult(strResult) {
  logger.addInfo("function parseIP4NetworkResult");
  idStart = strResult.indexOf("<id>");
  idEnd = strResult.indexOf("</id>");
  entityID = strResult.substring(idStart+4,idEnd);
  cidrpos = strResult.indexOf("CIDR=");
  delimitpos = strResult.indexOf("|");
  CIDR = strResult.substring(cidrpos+5, delimitpos);
  slashpos = CIDR.indexOf("/");
  networkPrefix0 = CIDR.substring(slashpos+1);
  networkPrefix = Number(networkPrefix0);
  gatewaypos = strResult.indexOf("gateway");
  inheritddpos = strResult.indexOf("inheritDefaultDomains");
  gateway = strResult.substring(gatewaypos+8,inheritddpos-1);
// logger.addInfo("entityID: " +entityID);
// logger.addInfo("CIDR: " +CIDR);
// logger.addInfo("networkPrefix: " +networkPrefix);
// logger.addInfo("typeof: "+typeof networkPrefix);
// logger.addInfo("Gateway: " +gateway);
  // NetMask Calculation
  switch (networkPrefix) {
  case 24:
  var netmask = "255.255.255.0";
  break;
  case 25:
  var netmask = "255.255.255.128";
  break;
  case 26:
  var netmask = "255.255.255.192";
  break;
  case 27:
  var netmask = "255.255.255.224";
  break;
  case 28:
  var netmask = "255.255.255.240";
  break;
  case 29:
  var netmask = "255.255.255.248";
  break;
  case 30:
  var netmask = "255.255.255.252";
  break;
  default: // 31
  var netmask = "255.255.255.254";
// logger.addInfo("netmask: " +netmask);
  return [entityID, CIDR, gateway, netmask];
} //function parseIP4NetworkResult
// Function Name: getNextHostNumber()
//       Version: 1.0
//   Description: Process/Read textfile stored on UCSD OVA that contains the last number
//                used in the hostname. Increment this value to return and re-write this
//                value into file
//        Inputs: hostnamePrefix  ;Result string to parse
//       Outputs: nextHostName    ;Returns the Object/Entity ID for the IP4 Network
function getNextHostNumber(hostnamePrefix) {
  this.hostnamePrefix = hostnamePrefix;
  var DIR_NAME = "/tmp";
  var PL_FILENAME = "last_plhostname";
  var PW_FILENAME = "last_pwhostname";
  var NL_FILENAME = "last_nlhostname";
  var NW_FILENAME = "last_nwhostname";
  switch (hostnamePrefix) {
  case "PL":
  var absoluteFilePath = DIR_NAME + File.separator + PL_FILENAME;
  break;
  case "PW":
  var absoluteFilePath = DIR_NAME + File.separator + PW_FILENAME;
  break;
  case "NL":
  var absoluteFilePath = DIR_NAME + File.separator + NL_FILENAME;
  break;
  default:  // NP
  var absoluteFilePath = DIR_NAME + File.separator + NW_FILENAME;
// logger.addInfo("File Path and Name: "+absoluteFilePath);
  // READ file to get the last hostname number used for that hostnamePrefix
  var br = new BufferedReader(new FileReader(absoluteFilePath));
  while(true) {
  var line = br.readLine();
  if (line == null) break;
  var lastHostNumber = line;
// logger.addInfo("Line: " +lastHostNumber);
  br.close();
  var pad = "000000"; //need right-padded zeros
  var nextHostNumber = parseInt(lastHostNumber) + 1;
// logger.addInfo("nextHostNumber: " +nextHostNumber);
  var nextHostnameCounter = pad.substring(0, pad.length - nextHostNumber.toString().length) +  nextHostNumber.toString();
  var nextHostName = hostnamePrefix+nextHostnameCounter;
// logger.addInfo("nextHostName: " +nextHostName);
  // WRITE file for the new hostname number used for that hostnamePrefix
  var bw = new BufferedWriter(new FileWriter(absoluteFilePath));
  bw.write(nextHostNumber.toString());
  bw.flush();
  bw.close();
  return nextHostName;
} //function getNextHostNumber
// Function Name: BluecatLogin()
//       Version: 1.0
//   Description: BAM API Authentication
//        Inputs: bluecatTransport  ;http or https
//                bluecatIP         ;BAM FQDN or IP
//                bluecatUser       ;BAM API Username
//                bluecatPassword   ;BAM API User password
//       Outputs: cookie            ;Returns JSESSIONID value
function BluecatLogin(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword) {
  logger.addInfo("function BluecatLogin");
  this.bcTransport = bluecatTransport;
  this.bcIP = bluecatIP;
  this.bcUser = bluecatUser;
  this.bcPassword = bluecatPassword;
  var apiName = "login";
  var msgXML ="<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:api=\"http://api.proteus.bluecatnetworks.com\">"
  +"<soapenv:Header/>"
   +"<soapenv:Body>"
     +"<api:login>"
        +"<username>"+bcUser+"</username>"
        +"<password>"+bcPassword+"</password>"
     +"</api:login>"
   +"</soapenv:Body>"
  +"</soapenv:Envelope>"
  request.setup(this.bcIP,this.bcTransport,null,null);
  request.postRequest('/Services/API', msgXML);
  var StatusCode = statusCode[0];
  var cookie = statusCode[1];
  if (StatusCode != 200)
  logger.addError("Request Failed. HTTP response code: "+statusCode);
  logger.addError("Response = "+request.getResponse("asString"));
  logger.addInfo("Response: " +response);
  ctxt.setFailed("Request failed.");
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:login>");
  logger.addInfo("");
  logger.addInfo("Response status: " +StatusCode);
  logger.addInfo("Status message : "+request.getStatusText());
  logger.addInfo("Response body: "+request.getResponseBodyAsString());
  return cookie;
} //function BluecatLogin
// Function Name: BluecatGetParent()
//       Version: 1.0
//   Description: Utility function used during the development of this integration.  This
//                function assists with determing the Parent entity ID for the inputted
//                Entity ID (e.g., determine the Parent Entity ID for the IP4 Network
//                which would be an IP4 Block)
//                jssessionid       ;Authentication cookie
//                entityId          ;Object ID
//       Outputs: statusCode        ;Returns POST status
// getParent
// UTILITY function can be used to determine an objects parentId
function BluecatGetParent(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid, entityId) {
  logger.addInfo("function BluecatGetParent");
// var entityid = input.entityId;
  this.jsessionid = String(jsessionid);
  var apiName = "getParent";
  logger.addInfo(apiName+": "+entityId);
   +"<soapenv:Body>"
      +"<api:getParent>"
         +"<entityId>"+entityId+"</entityId>"
      +"</api:getParent>"
   +"</soapenv:Body>"
  var reqhead = "Cookie";
  var reqvalue = "JSESSIONID="+this.jsessionid;
  request.addHeader(reqhead, reqvalue);
  if (statusCode != 200)
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:getParent>");
  logger.addInfo("");
  logger.addInfo("Response status code: " +statusCode);
  logger.addInfo("Response body: "+request.getResponse("asString"));
  return statusCode;
} //function BluecatGetParent
// Function Name: BluecatGetEntityByName()
//       Version: 1.0
//   Description: Returns object from the database referenced by their name field.
//                FUNCTION NOT CURRENTLY USED
//                parentId          ;Parent Object ID of the Entity
//                entityName        ;Name of the Entity
//                entityType        ;Entity Object Type
//       Outputs: outputValue       ;Return the Entity ID
function BluecatGetEntityByName(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid, parentId, entityName, entityType) {
  logger.addInfo("function BluecatGetEntityByName "+entityType+" "+entityName);
  var apiName = "getEntityByName";
   +"<soapenv:Body>"
      +"<api:getEntityByName>"
         +"<parentId>"+parentId+"</parentId>"
         +"<name>"+entityName+"</name>"
         +"<type>"+entityType+"</type>"
      +"</api:getEntityByName>"
   +"</soapenv:Body>"
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:getEntityByName>");
  logger.addInfo("");
  var requestOut = request.getResponse("asString");
  startpos = requestOut.indexOf("<id>");
  endpos = requestOut.indexOf("</id>");
  var outputValue = requestOut.substring(startpos+4, endpos);
// logger.addInfo("ID Value: " +outputValue);
  return outputValue;
} //function BluecatGetEntityByName
// Function Name: BluecatGetLinkedEntities()
//       Version: 1.0
//   Description: Returns an array of entities for the provided EntityID and Object Type.
//                BAM API can't be used to retrieve the linked entities of an IP4 Network,
//                received response "Link request is not supported"; can't be used to
//                retrieve sub-Tags
//                entityId          ;Entity Id
//                entityType        ;Entity Object TYpe
//       Outputs: returnResult      ;Returns the Response String for further processing
function BluecatGetLinkedEntities(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid, entityId, entityType) {
  logger.addInfo("function BluecatGetLinkedEntities "+entityId+" "+entityType);
  var apiName = "getLinkedEntities";
   +"<soapenv:Body>"
      +"<api:getLinkedEntities>"
         +"<start>0</start>"
         +"<count>10</count>"
      +"</api:getLinkedEntities>"
   +"</soapenv:Body>"
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:getLinkedEntities>");
  logger.addInfo("");
// logger.addInfo("requestOut typeof: " +typeof requestOut);
  //Need to count the number of xml tag <item>
  var patternCount = getCount(String(requestOut),"item");
// logger.addInfo("Number Times <item>: "+patternCount);
// logger.addInfo("patternCount typeof: " +typeof patternCount);
  var returnStart = requestOut.indexOf("<return>");
  var returnEnd = requestOut.indexOf("</return>");
  var ro = requestOut.substring(returnStart+8, returnEnd);
// logger.addInfo("ro: " +ro);
// var res = ro.slice("</item>");
// logger.addInfo("res: " +res);
  var returnResult = new Array();
  for (i = patternCount; i > 0; i--) {
  var itemStart = ro.indexOf("<item>");
  var itemEnd = ro.indexOf("</item>");
  var roCurrent = ro.substring(itemStart+6, itemEnd);
  var ro = ro.substring(itemEnd+7);
// logger.addInfo("roCurrent: " +roCurrent);
  returnResult.push(roCurrent);
// logger.addInfo("returnResult typeof: " +typeof returnResult);
  return returnResult;
} //function BluecatGetLinkedEntities
// Function Name: BluecatGetNextAvailableIP4Network()
//       Version: 1.0
//   Description: Returns the object ID for the next available (unused) network within
//                a block.
//                ip4BlockOID       ;Object ID of IP4 Block
//       Outputs: statusCode        ;Returns response status code
//                nextIP4Network    ;Returns the next IP4 Network
function BluecatGetNextAvailableIP4Network(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid, ip4BlockOID) {
  logger.addInfo("function BluecatGetNextAvailableIP4Network " +ip4BlockOID);
  var apiName = "getNextAvailableIP4Network";
   +"<soapenv:Body>"
      +"<api:getNextAvailableIP4Range>"
         +"<parentId>"+ip4BlockOID+"</parentId>"
  +"<size>24</size>"
  +"<type>IP4Network</type>"
  +"</properties>"
      +"</api:getNextAvailableIP4Range>"
   +"</soapenv:Body>"
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:getNextAvailableIP4Network>");
  logger.addInfo("");
  var strResult = request.getResponse("asString");
  returnStart = strResult.indexOf("<return>");
  returnEnd = strResult.indexOf("</return>");
  nextIP4Network = strResult.substring(returnStart+8,returnEnd);
// logger.addInfo("Next Available IPv4 Network: " +nextIP4Network);
  return [statusCode, nextIP4Network];
} // function BluecatGetNextAvailableIP4Network
// Function Name: BluecatGetNextAvailableIP4Address()
//       Version: 1.0
//   Description: Returns the IPv4 address for the next available (unallocated) address
//                within a network.
//                ip4NetworkOID     ;Object ID for IP4 Network
function BluecatGetNextAvailableIP4Address(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid, ip4NetworkOID) {
  logger.addInfo("function BluecatGetNextAvailableIP4Address " +ip4NetworkOID);
  var apiName = "getNextAvailableIP4Address";
   +"<soapenv:Body>"
      +"<api:getNextAvailableIP4Address>"
         +"<parentId>"+ip4NetworkOID+"</parentId>"
      +"</api:getNextAvailableIP4Address>"
   +"</soapenv:Body>"
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:getNextAvailableIP4Address>");
  logger.addInfo("");
// SAMPLE RETURNED RESULT
//<env:Envelope xmlns:env='http://schemas.xmlsoap.org/soap/envelope/'><env:Header></env:Header><env:Body><api:getNextAvailableIP4AddressResponse xmlns:api='http://api.proteus.bluecatnetworks.com'><return>10.8.132.1</return></api:getNextAvailableIP4AddressResponse></env:Body></env:Envelope>
  nextIP4Address = strResult.substring(returnStart+8,returnEnd);
// logger.addInfo("Next Available IPv4: " +nextIP4Address);
  return [statusCode, nextIP4Address];
} //function BluecatGetNextAvailableIP4Address
// Function Name: BluecatGetHostRecordsByHint()
//       Version: 1.0
//   Description: Returns an array of objects with host record type; Used to check if
//                derived hostname is already used in DNS
//                nextHostname      ;Derived next hostname
// Check to see if the Hostname exists
function BluecatGetHostRecordsByHint(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid, nextHostname) {
  logger.addInfo("function BluecatGetHostRecordsByHint " +nextHostname);
  var apiName = "getHostRecordsByHint";
  var hint = "hint=^"+String(nextHostname)+"$";
   +"<soapenv:Body>"
      +"<api:getHostRecordsByHint>"
         +"<start>0</start>"
         +"<count>1</count>"
         +"<options>"+hint+"</options>"
      +"</api:getHostRecordsByHint>"
   +"</soapenv:Body>"
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:getHostRecordsByHint>");
  logger.addInfo("");
  //StatusCode 200 received if hostname exists or not
  //if idpos > 0, then hostname exists
  var idpos = request.getResponse("asString").indexOf("<id>");
  if (idpos >= 0) {
  statusCode = 500;
  return statusCode;
} //function BluecatGetHostRecordsByHint
// Function Name: BluecatAddHostRecord()
//       Version: 1.0
//   Description: Creates a new DNS A Record and Assigns the IP4 Address
//                nextHostname      ;Derived hostname
//                domain            ;Domain suffix (tst.genco.com or genco.com)
//                nextIP4Address    ;IP4 Address to assign with hostname
//       Outputs: nextFQDN          ;Returns FQDN
function BluecatAddHostRecord(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid, nextHostname, domain, nextIP4Address) {
  logger.addInfo("function BluecatAddHostRecord " +nextHostname+ " " +domain+ " " +nextIP4Address);
  var dnsViewOID = input.dnsViewOID; //internal
  this.domainName = "."+domain;
  nextFQDN = nextHostname.concat(this.domainName);
  var apiName = "addHostRecord";
   +"<soapenv:Body>"
      +"<api:addHostRecord>"
         +"<viewId>"+dnsViewOID+"</viewId>"
         +"<absoluteName>"+nextFQDN+"</absoluteName>"
         +"<addresses>"+nextIP4Address+"</addresses>"
         +"<ttl>-1</ttl>"
         +"<properties/>"
      +"</api:addHostRecord>"
   +"</soapenv:Body>"
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:addHostRecord>");
  logger.addInfo("");
  return nextFQDN;
} //function BluecatAddHostRecord
// Function Name: BluecatLogout()
//       Version: 1.0
//   Description: Logout to close BAM API Connection
//       Outputs: true              ;
function BluecatLogout(bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, jsessionid) {
  logger.addInfo("function BluecatLogout");
  var apiName = "logout";
   +"<soapenv:Body>"
     +"<api:logout/>"
   +"</soapenv:Body>"
  } else {
  logger.addInfo("");
  logger.addInfo("");
  logger.addInfo("<api:getEntityById>");
  logger.addInfo("");
  return true;
} //function BluecatLogout
// main();
// Workflow Inputs Mappings
var bluecatIP = input.BluecatIP;
var bluecatTransport = input.BluecatTransport;
var bluecatAccount = getAccount(String(input.BluecatAccount));
var networkType = String(input.GenCoNetwork);
var hostOS = String(input.GenCoHostOSType);
//logger.addInfo("Network LOV: " +networkType);
//logger.addInfo("HostOS LOV: " +hostOS);
var bluecatUser = bluecatAccount.getUserName();
var bluecatPassword = bluecatAccount.getPassword();
var session = BluecatLogin (bluecatTransport, bluecatIP, bluecatUser, bluecatPassword);
// FUNCTION ONLY USED FOR UNIT TESTING TO DERIVE THE PARENTID IF YOU CAN'T LOCATE IN Bluecat Address Manager UI
//var request = BluecatGetParent (bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, session, input.entityID);
switch (networkType) {
  case "P": //Production
  case "p":
  var entityID = String(input.prodTagNameEntityID);
  var domain = "genco.com";
  break;
  default: // Non-Production
  var entityID = String(input.nonprodTagNameEntityID);
  var domain = "tst.genco.com";
var entityType = "IP4Network";
var retrieveNetwork = false;
// Retrieve all IP4 Networks that are Tagged
var ip4NetworkArray = BluecatGetLinkedEntities (bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, session, entityID, "IP4Network");
var arrayLength = ip4NetworkArray.length;
//logger.addInfo("Number Tagged IP4 Networks: " +arrayLength);
while (retrieveNetwork == false) {
  // Retrieve an IP4 Block from the returned array
  var ip4Network = ip4NetworkArray.shift();
// logger.addInfo("ip4Network: " +ip4Network);
  //<id>614603</id><name xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xsi:nil='true'/><properties>CIDR=10.8.132.0/24|allowDuplicateHost=enable|inheritAllowDuplicateHost=true|pingBeforeAssign=disable|inheritPingBeforeAssign=true|gateway=10.8.132.254|inheritDefaultDomains=true|defaultView=87576|inheritDefaultView=true|inheritDNSRestrictions=true|</properties><type>IP4Network</type>
  var ip4NetworkResults = parseIP4NetworkResult(ip4Network);
  //logger.addInfo("ip4NetworkResults typeof: " +typeof ip4NetworkResults);
  //logger.addInfo("ip4NetworkResults: " +ip4NetworkResults);
  // Retrieve IP4Network entityId
  // Retrieve IP4Network CIDR
  // Retrieve IP4Network gateway
  var ip4networkentityid = ip4NetworkResults[0];
  var cidr = ip4NetworkResults[1];
  var gateway = ip4NetworkResults[2];
  var netmask = ip4NetworkResults[3];
  //logger.addInfo("ip4networkentityid: " +ip4networkentityid);
  //logger.addInfo("cidr: " +cidr);
  //logger.addInfo("gateway: " +gateway);
  //logger.addInfo("netmask: " +netmask);
  // Based on a successfully Returned IP4 Network
  // Retrieve the next available IP4 Address
  var nextip4address = BluecatGetNextAvailableIP4Address (bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, session, ip4networkentityid);
  var nextip4addressStatus = nextip4address[0];
  if (parseInt(nextip4addressStatus) == 200) {
  // Found an available IP4 Address
  // Don't need to move to the next IP4 Network to find an available IP4 Address
  var nextip4add = nextip4address[1];
// logger.addInfo("Next IP4 Address: " +nextip4add);
  retrieveNetwork = true;
// Generate the Hostname Prefix
var hostnamePrefix = networkType+hostOS;
//logger.addInfo("hostnamePrefix: " +hostnamePrefix);
var hostnameExists = false;
var heCount = 1;
while (hostnameExists == false) {
  // Generate new hostname
  var nextHost = getNextHostNumber(hostnamePrefix);
  // Check to see if hostname has been assigned
  var hostnameStatus = BluecatGetHostRecordsByHint (bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, session, nextHost);
  if (parseInt(hostnameStatus) == 200) {
  // hostname is not assigned
  hostnameExists = true;
} //while (hostnameExists == false)
// logger.addInfo("nextHost: " +nextHost);
// Create the DNS Entry
var fqdnStatus = BluecatAddHostRecord (bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, session, nextHost, domain, nextip4add);
var close = BluecatLogout (bluecatTransport, bluecatIP, bluecatUser, bluecatPassword, session);
// Workflow Outputs Mappings
output.CIDR = cidr;
output.nextIP4Address = nextip4add;
output.gateway = gateway;
output.netmask = netmask;
output.nextHostname = nextHost;
output.nextFQDN = nextHost + "." + domain;
The API guide (please request from Blue Cat):
