markpsmi
Attached workflow uses UCS Central Tasks to provision bare metal server with CentOS 7.3 and 2 Management NICs. Each with different IP addresses. Workflow creates Global Service Profile from Template and then adds PXE Nics for the PXE boot process. The PXE NICs are defined as vNIC Templates. The Global Service Profile uses Update Template so it is it's Unbound before the Add Vlans Task adds the PXE Nics.Then Global Service Profile is Rebound to the Template after PXE process so the Management NICs can use the native vlans. Included in the zip file for the workflow is also the ks.cfg and pxe.cfg files.
The IP configuration is done with variables in the Workflow that update in the ks.cfg. See lines below from the kickstart script (ks.cfg).
%post
## Notifying back to Cisco UCS Director once the blade is up ##
wget http://$PXE_WEBSERVER/$PXEID/notify.html
# Configure IP on ETH0
echo DEVICE=eth0 > /etc/sysconfig/network-scripts/ifcfg-eth0
echo HWADDR=$HWADDR1 >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo BOOTPROTO=static >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo ONBOOT=yes >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo IPADDR=$PXE_IP >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo NETMASK=$PXE_NETMASK >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo GATEWAY=$PXE_GATEWAY >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo DNS1=$PXE_NS >> /etc/sysconfig/network-scripts/ifcfg-eth0
# Configure IP on ETH1
echo DEVICE=eth1 > /etc/sysconfig/network-scripts/ifcfg-eth1
#echo HWADDR=$HWADDR2 >> /etc/sysconfig/network-scripts/ifcfg-eth1
echo BOOTPROTO=static >> /etc/sysconfig/network-scripts/ifcfg-eth1
echo ONBOOT=yes >> /etc/sysconfig/network-scripts/ifcfg-eth1
echo IPADDR=$NET_PXE_IP2 >> /etc/sysconfig/network-scripts/ifcfg-eth1
echo NETMASK=$NET_PXE_NETMASK2 >> /etc/sysconfig/network-scripts/ifcfg-eth1
# Configure Hostname
echo NETWORKING=yes > /etc/sysconfig/network
echo HOSTNAME=$PXE_NAME >> /etc/sysconfig/network
