Orf Gelbrich
Presented by Luca Relandini
This posts on my blog describe the C1ECS-CliQr integration.
This implementation was for a customer demo about applications and hybrid cloud.
The post describes the need for a unified dashboard and governance from a business standpoint:
http://lucarelandini.blogspot.com/2016/02/governance-in-hybrid-cloud.html
UCSD 5.4.0.0 was used.
The UCSD workflows and Custom Tasks:
Impressions from the Demo Environment:
ucsd4.pngucsd3.pngucsd2.pngucsd1.pngSelectReport.pngrep4.pngrep3.pngrep2.pngrep1.pngdash3.pngdash2.pngdash1.png
Side Notes:
It should be enough to reproduce the demo, if you have CliQr and AWS/Azure accounts.
There is also a mock dashboard, with static images, just to show what could be built (with Jquery graphs in PSC, some database tables and a scheduled pull from the CliQr/UCSD/ICFD API)
The yellow text should be replaced with data from your environment.
Other Blog posts by Luca:
Orchestration of a 3 tier application on 3 hypervisors, with Openstack and Cisco ACI, later ported to UCS Director + Openstack
DevOps (4 posts) - Continuous Integration and Continuous Deployment for both applications and infrastructure
Application Centric Infrastructure (ACI) - starting with a ACI for Simple Minds post.
Data Center automation and UCS Director - how to invoke a workflow via REST API
Openstack - What Cisco is doing in this area: plugins and innovation
Docker, Containers and Microservices - part 1 and part 2
