Orf Gelbrich
Task NameExample of looking at a vCenter and at every host name and comparing it to input to see if this hostname is already in existence.
Description
Prerequisites
Tested on 5.5
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
The Workflow:
User Input to Workflow:
Run when not found:
Run when found:
Somersbd99
Community Member
Good ideal but seems to not take the case of the VM name into account. If the name inside vcenter is SERVER1 in upper case entering server1 into the check name field returns the server does not exist check.
Is there a way to take case into account as well?
Orf Gelbrich
If you open up the custom task the if/compare would have to change
But I am wondering since the custom task is looking at a screen in UCSD how the name shows up in the UCSD screen.
Do you have a log section where it should find it amongst your VM’s and it is not.
Somersbd99
Community Member
Orf Gelbrich
Hit submit to quick?
Orf Gelbrich
In the custom task this line(72)
if ( new java.lang.String(hostname).equals(new java.lang.String(Name)) )
Would have to be replaced with something like from this posting
https://stackoverflow.com/questions/2140627/javascript-case-insensitive-string-comparison
you would have to make sure the strings are either converted to upper or lower case..
UCSD is case sensitive – it is linux.
Somersbd99
Community Member
I ended up using your Case Sensitive / Insensitive workflow (#359) with an IfElse looking for the VMsFound == “1” condition. Works great using that RegExFilter.
I wanted something to check the name prior to starting the VM provisioning instead of just the generic error.
thanks
Orf Gelbrich
In UCSD 6.6 we are getting Bash/Python/javascript workflow form pre processing checking. Meaning you fill out the form and it will check when you hit submit but before the workflow runs. UCSD 6.6 will be out by March 31. ☺
Somersbd99
Community Member
That is good news, something that is definitely needed. Is 6.6 still on track for release?
thanks
Orf Gelbrich
Just got this from the BU
Planned for the end of April / around 23rd April, final date is tbd
Somersbd99
Community Member
Thanks for the info.
