Orf Gelbrich
Task NameTest is a host is listening on a specific port
Description
Prerequisites
  1. Tested on 6.0
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
OutputID
  8. Click "Submit".
Thank you goes to:   Phani Penmethsa
The workflow:
Workflow Import:
Workflow location:
Input for custom task:
Workflow run when Device is listening:
Workflow run when Device is not listening:
The custom task code:
i
mportPackage(java.lang);
importPackage(java.net);
importPackage(java.io);
function isReachable(count)
         try
              var s = new Socket(input.ipAddress, input.tcpPort);
              s.close();
              return true;
          } catch(e)
                if (count == 0)
                      logger.addDebug("IP Address "+input.ipAddress +":"+ input.tcpPort + " not reachable");
                return false;
var start = System.currentTimeMillis();
var stopTime = start + input.maxWaitSeconds * 1000;
var count  = 0;
while (System.currentTimeMillis() < stopTime)
       if (isReachable(count) === true)
             logger.addInfo("Device is reachable");
             ctxt.exit();
        count++;
       if (count === 3)
             count = 0;
       Thread.sleep(10000);
ctxt.setFailed("Maximum wait time exceeded for device");
ctxt.exit();
