kesimmon
Task Name
Check Password
Description
Validates password pair matches and meets specified requirements
Prerequisites
Validated on UCSD 5.3.1.1
Category
Workflow Task
Components
UCS Director
User Inputs
  1. Password
  2. Confirm Password
  3. Minimum Number of Characters
  4. Number of Character Types
  5. Must Have Number
  6. Must Have Lower Case Character
  7. Must Have Upper Case Character
  8. Must Have Special Character
Output
Result of operation
Summary
When creating passwords for new users, corporate standards may have specific requirements for the content of the password (for example, when using UCS Director to create new user accounts, the password must meet the requirements defined in Active Directory).  This workflow task validates the password meets the minimum requirements.
Installation
  2. Unzip the file on your computer. Should end up with a .WFDX file.
  8. Click "Submit".
Usage
See attached document “UCS Director – Check Password”
The workflow also includes a sample Unit Test script that can be used to validate the custom task against different releases of UCS Director.
Example
Verify the passwords entered into the workflow match and are at least six characters and have at least one of the three “Has…” categories below.
