Orf Gelbrich
Task NameCOnvert Lower Case to Upper Case
Description
Prerequisites
Minimum UCSD version: 5.4.0.1
CategoryCustom task
Components
User Inputs
User OutputOutputString
  8. Click "Submit".
The workflow:
The workflow execution:
The workflow run:
The input and output variables:
The Java Script:
importPackage(java.util);
importPackage(java.lang);
importPackage(java.io);
importPackage(com.cloupia.model.cEvent.notify);
importPackage(com.cloupia.model.cIM);
importPackage(com.cloupia.lib.util.mail);
importPackage(com.cloupia.fw.objstore);
importPackage(com.cloupia.lib.util.managedreports);
var a1 = input.A;
logger.addInfo("a1 ;  " + a1);
output.A_Prime = a1.toUpperCase();
