Harpreet Singh Dahri
Workflow Name:
Create entry in ServiceNow
Description:
This will allow you to create a new entry in the ServiceNow CMDB for the newly created VM.
Update the ServiceNow instance details (instance ID, username & password) in the "Execute Cloupia Script" before trying to execute it.
Compatible UCS Director Versions:UCSD 5.0.x.x
Category:
Virtualization, ServiceNow
Instructions for Use:
  1. Download the attached .ZIP file below to your computer.
    *Remember the location of the saved file on your computer.
  3. Log in to UCS Director as a user that has
    "system-admin" privileges.
  4. Navigate to "Policies-->Orchestration" and click on
    "Import".
  5. Click "Browse" and navigate to the location on your
    computer where the .WFD file resides. Choose the .WFD file and click "Open".
  6. Click "Upload" and then "OK" once the file
    upload is completed. Then click "Next".
  7. Click the "Select" button next to "Import
    Workflows". Click the "Check All" button to check all checkboxes
    and then the "Select" button.
  8. Click "Submit".
  9. A new folder should appear in
    "Policies-->Orchestration" that contains the imported workflow.
    You will now need to update the included tasks with information about the
    specific environment.
