Orf Gelbrich
Task NameCreate VM Memory Reservation in vCenter
Description
Prerequisites
Minimum UCSD version: 5.4
CategoryCustom task
Components
User Inputs
·         vDC Id
·         VM Name (which VM we are going to reserve memory).
·         Memory In MB(Reserved Memory)
User OutputVMwareDVPortgroupIdentity
  8. Click "Submit".
A thank you goes out to: Apparao Nadipineni
This task will change the memory reservation for a VM:
Workflow inputs:
Workflow result in vCenter:
