Orf Gelbrich
Task NameExample on converting UCS VLAN from one type to another varaible type
Description
Prerequisites
Tested on 5.5
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Caveat:
This example converts the variable type.  The actual content on the variable needs to be addressed for the situation the workflow will run in. Please read below for possible mythology to obtain the exact syntax.
The Workflow:
The code in the custom task
The custom task input type:
The custom task output type:
Results from workflow import:
Mythology example (Tank you Eric Thirolle):
Example, the UCSD task named "Add VLANS to VLAN Group".
Add the task in questions to its own new workflow. In the task wizard, do NOT map the inputs:
This forces you to pick the inputs from selector boxes:
We run this workflow, then look at the “Inputs / Outputs” tab in the SR dialog. Here is what I got when I tried this:
What we can see from that screenshot is:
• The “vlan” input to this task is not a list of VLAN IDs, it is a list of “VLAN Identities”
• Each VLAN has a syntax like, ”Lab-UCSM;fabric/lan/net-IACPXE501”. The first part is the Account Name for the UCSM physical account you set up in UCSD (as shown in the second screenshot above). The second part is the “DN” (also seen in the second screenshot above). The two parts are separated by a semicolon.
odahlqvist
Level 4
Level 4
i am trying to create and add a UCS vlan to a VLAN group do i need this feature , tried but its not working yet
