Orf Gelbrich
Task Name
Report example on how to get the APIC application Tenant Profile Name.
Description
Prerequisites
Tested on UCSD 6.0.0.0
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Workflow:
The custom task as well as the Cloupia script are included.
Input:
The Log:
Service Request ID: 361
Workflow Inputs:
- outa1
- outa2
- APIC_Tenant
- Email Address
Jan 19, 2017 15:55:00 UTC Request submitted
Jan 19, 2017 15:55:05 UTC Executing workflow item number 1
Jan 19, 2017 15:55:05 UTC Completed workflow item number 1, with status Completed
Jan 19, 2017 15:55:11 UTC Executing workflow item number 2
Jan 19, 2017 15:55:11 UTC Trigger context executeWorkFlowStep called
Jan 19, 2017 15:55:12 UTC Executing custom action ReportAPICTenantProfiles (custom_APICTenantApplicationProfile)
Jan 19, 2017 15:55:12 UTC Executing custom script for APICTenantApplicationProfile
Jan 19, 2017 15:55:12 UTC Input : OracleAPIC@infra
Jan 19, 2017 15:55:12 UTC Input 0 : OracleAPIC
Jan 19, 2017 15:55:12 UTC Input 1 : infra
Jan 19, 2017 15:55:12 UTC numRowsFound : 1
Jan 19, 2017 15:55:12 UTC DN: uni/tn-infra/ap-access
Jan 19, 2017 15:55:12 UTC Application Profile Name: access
Jan 19, 2017 15:55:12 UTC Tenant: infra
Jan 19, 2017 15:55:12 UTC Description:
Jan 19, 2017 15:55:12 UTC QOS Class: unspecified
Jan 19, 2017 15:55:12 UTC DN 0: uni
Jan 19, 2017 15:55:12 UTC DN 1: tn-infra
Jan 19, 2017 15:55:12 UTC Dn 2: ap-access
Jan 19, 2017 15:55:12 UTC Processing output: a0
Jan 19, 2017 15:55:12 UTC Processing output: a1
Jan 19, 2017 15:55:12 UTC Processing output: a2
Jan 19, 2017 15:55:12 UTC Processing output: a3
Jan 19, 2017 15:55:12 UTC Processing output: a4
Jan 19, 2017 15:55:12 UTC Processing output: dn0
Jan 19, 2017 15:55:12 UTC Processing output: dn1
Jan 19, 2017 15:55:13 UTC Processing output: dn2
Jan 19, 2017 15:55:13 UTC Task #2 (ReportAPICTenantProfiles (custom_APICTenantApplicationProfile)) completed successfully in 1 seconds
Jan 19, 2017 15:55:13 UTC Input/Output values for Task #2 (ReportAPICTenantProfiles (custom_APICTenantApplicationProfile)):
Jan 19, 2017 15:55:13 UTC [Mapped Input: APICTenant = OracleAPIC@infra]
Jan 19, 2017 15:55:13 UTC [Output: a0 = uni/tn-infra/ap-access]
Jan 19, 2017 15:55:13 UTC [Output: a1 = access]
Jan 19, 2017 15:55:13 UTC [Output: a2 = infra]
Jan 19, 2017 15:55:13 UTC [Output: a3 = ]
Jan 19, 2017 15:55:13 UTC [Output: a4 = unspecified]
Jan 19, 2017 15:55:13 UTC [Output: dn0 = uni]
Jan 19, 2017 15:55:13 UTC [Output: dn1 = tn-infra]
Jan 19, 2017 15:55:13 UTC [Output: dn2 = ap-access]
Jan 19, 2017 15:55:13 UTC Completed workflow item number 2, with status Completed
Jan 19, 2017 15:55:14 UTC Executing workflow item number 3
Jan 19, 2017 15:55:14 UTC Trigger context executeWorkFlowStep called
Jan 19, 2017 15:55:14 UTC Executing custom action ReportAPICTenantProfiles (ExecuteCloupiaScript)
Jan 19, 2017 15:55:15 UTC Executing cloupia script: ReportsAPICTenantProfiles
Jan 19, 2017 15:55:15 UTC AT : OracleAPIC@infra
Jan 19, 2017 15:55:15 UTC 0 : OracleAPIC
Jan 19, 2017 15:55:15 UTC 1 : infra
Jan 19, 2017 15:55:15 UTC numRowsFound : 1
Jan 19, 2017 15:55:15 UTC report: com.cloupia.lib.util.managedreports.TableView@14bd62fc
Jan 19, 2017 15:55:15 UTC DN: uni/tn-infra/ap-access
Jan 19, 2017 15:55:15 UTC Profile02: access
Jan 19, 2017 15:55:15 UTC Tenant: infra
Jan 19, 2017 15:55:15 UTC Description:
Jan 19, 2017 15:55:15 UTC QOS Class: unspecified
Jan 19, 2017 15:55:15 UTC DN 0: uni
Jan 19, 2017 15:55:15 UTC DN 1: tn-infra
Jan 19, 2017 15:55:15 UTC Dn 2: ap-access
Jan 19, 2017 15:55:15 UTC Sending email
Jan 19, 2017 15:55:15 UTC Completed cloupia script ReportsAPICTenantProfiles
Jan 19, 2017 15:55:15 UTC Task #3 (ReportAPICTenantProfiles (ExecuteCloupiaScript)) completed successfully in 0 seconds
Jan 19, 2017 15:55:15 UTC Input/Output values for Task #3 (ReportAPICTenantProfiles (ExecuteCloupiaScript)):
Jan 19, 2017 15:55:15 UTC [Local Input: Label = ReportsAPICTenantProfiles]
Jan 19, 2017 15:55:15 UTC [Local Input: Script = importPackage(java.util); importPackage(java.lang); importPackage(java.io); importPackage(com.cloupia.model.cEvent.notify); importPackage(com.cloupia.model.cIM); importPackage(com.cloupia.lib.util.mail); importPackage(com.cloupia.fw.objstore); importPackage(com.cloupia.lib.util.managedreports); importPackage(com.cloupia.service.cIM.inframgr.profiles); importPackage(com.cloupia.service.cIM.inframgr); function getMailSettings() { return ObjStoreHelper.getStore((new MailSettings()).getClass()).getSingleton(); } function getReport(reportContext, reportName) { var report = null; try { report = ctxt.getAPI().getConfigTableReport(reportContext, reportName); } catch(e) { } if (report == null) { return ctxt.getAPI().getTabularReport(reportName, reportContext); } else { var source = report.getSourceReport(); return ctxt.getAPI().getTabularReport(source, reportContext); } } function getReportView(reportContext, reportName) { var report = getReport(reportContext, reportName); if (report == null) { logger.addError('No such report exists for the specified context '+reportName); return null; } return new TableView(report); } // Assume the To Email Addres is in the input variable 'Email Address' var toEmail = [ ctxt.getInput('Email Address') ]; var message = new EmailMessageRequest(); message.setToAddrs(toEmail); message.setSubject('APIC Tenant Profile Report'); message.setFromAddress('no-reply@cisco.com'); var buffer = new StringWriter(); var printer = new PrintWriter(buffer); // Formatter exists in multiple packages, so it needs fully qualified name var formatter = new com.cloupia.lib.util.managedreports.Formatter(new File('.'), printer); var AT = ctxt.getInput('APIC_Tenant'); logger.addInfo('AT : ' + AT); var x = AT.split('@'); logger.addInfo('0 : ' + x[0]); logger.addInfo('1 : ' + x[1]); var reportName='apic.tenant.appln.profile.report.config'; var repContext = util.createContextByType( '90160','','accountName=='' + x[0] +'' && name=='' + x[1] +'''); var report = getReportView(repContext, reportName); var i=0; var numRowsFound = report.rowCount(); logger.addInfo('numRowsFound : ' + numRowsFound); logger.addInfo('report: ' + report); var a0 = report.getColumnValue(0, 'DN'); logger.addInfo('DN: ' + a0); //var a1 = report.getColumnValue(0, 'Application Profile Name'); var a1 = report.getColumnValue(0, 'Name'); logger.addInfo('Profile02: ' + a1); var a2 = report.getColumnValue(0, 'Tenant '); logger.addInfo('Tenant: ' + a2); var a3 = report.getColumnValue(0, 'Description'); logger.addInfo('Description: ' + a3); var a4 = report.getColumnValue(0, 'QoS Class'); logger.addInfo('QOS Class: ' + a4); var sp = a0.split('/'); logger.addInfo('DN 0: ' + sp[0]); logger.addInfo('DN 1: ' + sp[1]); logger.addInfo('Dn 2: ' + sp[2]); ctxt.updateInput('outa1', sp[2]); formatter.printTable(report); printer.close(); var body = '<head><style type='text/css'>'; // Specify CSS for the report body = body + 'table { font-family: Verdana, Geneva, sans-serif; font-size: 12px; border: thin solid #039; border-spacing: 0; background: #ffffff; } '; body = body + ' th { background-color: #6699FF; color: white; font-family: Verdana, Geneva, sans-serif; font-size: 10px; font-weight: bold; border-color: #CCF; border-style: solid; border-width: 1px 1px 0 0; margin: 0; padding: 5px; } '; body = body + ' td { font-family: Verdana, Geneva, sans-serif; font-size: 10px; border-color: #CCF; border-style: solid; border-width: 1px 1px 0 0; margin: 0; padding: 5px; background: #ffffff; }'; body = body + '</style></head>'; body = body+ '<body><h1>VDC 1 Report</h1><br>' + buffer.toString(); message.setMessageBody(body); logger.addInfo('Sending email'); // Now, send the report via email. First parameter is just a label used in the // internal logs MailManager.sendEmail('VDC approver report', getMailSettings(), message); ]
Jan 19, 2017 15:55:15 UTC [Local Input: Undo Script = ]
Jan 19, 2017 15:55:15 UTC Completed workflow item number 3, with status Completed
Jan 19, 2017 15:55:17 UTC Executing workflow item number 4
Jan 19, 2017 15:55:17 UTC Trigger context executeWorkFlowStep called
Jan 19, 2017 15:55:17 UTC Executing custom action ReportAPICTenantProfiles (Send Email)
Jan 19, 2017 15:55:18 UTC Sending email to ogelbric@cisco.com, with Subject APIC Tenant Profle
Jan 19, 2017 15:55:18 UTC Task #4 (ReportAPICTenantProfiles (Send Email)) completed successfully in 0 seconds
Jan 19, 2017 15:55:18 UTC Input/Output values for Task #4 (ReportAPICTenantProfiles (Send Email)):
Jan 19, 2017 15:55:18 UTC [Local Input: E-mail Addresses = ogelbric@cisco.com]
Jan 19, 2017 15:55:18 UTC [Local Input: Subject = APIC Tenant Profle]
Jan 19, 2017 15:55:18 UTC [Template Input:Body = ${outa1}]
Jan 19, 2017 15:55:18 UTC [Resolved Template Input: Body = ap-access]
Jan 19, 2017 15:55:18 UTC [Local Input: Body = ap-access]
Jan 19, 2017 15:55:18 UTC [Output: EMAIL_ADDRESSES = ogelbric@cisco.com]
Jan 19, 2017 15:55:18 UTC Completed workflow item number 4, with status Completed
Jan 19, 2017 15:55:23 UTC Executing workflow item number 5
Jan 19, 2017 15:55:23 UTC Completed workflow item number 5, with status Completed
The Custom Task:
     var report = null;
      try
      } catch(e)
      if (report == null)
      } else
     if (report == null)
           logger.addError("No such report exists for the specified context "+reportName);
           return null;
var formatter = new com.cloupia.lib.util.managedreports.Formatter(new File("."), printer);
var AT = input.APICTenant;
logger.addInfo("Input : " + AT);
logger.addInfo("Input 0 : " + x[0]);
logger.addInfo("Input 1 : " + x[1]);
var reportName="apic.tenant.appln.profile.report.config";
var repContext = util.createContextByType( "90160","","accountName=='" + x[0] +"' && name=='" + x[1] +"'");
logger.addInfo("numRowsFound : " + numRowsFound);
var aa0 = report.getColumnValue(0, "DN");
logger.addInfo("DN: " + aa0);
//var a1 = report.getColumnValue(0, "Application Profile Name"); Apparently heading is actuall just Name
var aa1 = report.getColumnValue(0, "Name");
logger.addInfo("Application Profile Name: " + aa1);
var aa2 = report.getColumnValue(0, "Tenant ");
logger.addInfo("Tenant: " + aa2);
var aa3 = report.getColumnValue(0, "Description");
logger.addInfo("Description: " + aa3);
var aa4 = report.getColumnValue(0, "QoS Class");
logger.addInfo("QOS Class: " + aa4);
var sp = aa0.split('/');
logger.addInfo("DN 0: " + sp[0]);
logger.addInfo("DN 1: " + sp[1]);
logger.addInfo("Dn 2: " + sp[2]);
output.a0 = aa0;
output.a1 = aa1;
output.a2 = aa2;
output.a3 = aa3;
output.a4 = aa4;
output.dn0 = sp[0];
output.dn1 = sp[1];
output.dn2 = sp[2];
printer.close();
phirobin
Community Member
great - thanks Orf - the Heading Application Profile Name = Name is the bit that threw me - though it's not the first time that has happened with the report name headers not matching the variables
Orf Gelbrich
Trying to keep I generic for the next report that needs this…
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities Site (Twitter @UCSDGURU)
