Orf Gelbrich
Task Name
Get best Datastore and get best ESXi host
Description
Prerequisites
  1. Tested on 5.4
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
Output
  5. Click "Browse" and navigate to the location on your computer where the .WFDX file resides. Choose the .WFDX file and click "Open".
  8. Click "Submit".
  9. A new folder should appear in "Policies-->Orchestration" that contains the imported workflow. You will now need to update the included tasks with information about the specific environment
Thank you for creating this a big thank you goes out to:  Alejandro Madurga Ainoza
This workflow gets the host from a cluster with the least amount of memory overcommitted and the best datastore with most space availalble.
Thanks for this Orf, much appreciated!
cristel1221
Level 5
Level 5
i agree with Amanda
ceci13501
Level 5
Level 5
correct!
