Orf Gelbrich
Task Name
Mo Create /cloupis/api-v2 example
Description
Prerequisites
Tested on UCSD  6.5
CategoryWorkflow
ComponentsvSphere 5.x
User Inputsinputs length have been tested up to 1300 characters
  8. Click "Submit".
The workflow input:
The custom task input (Notice the global workflow input variable ${MYVMID}):
From the RestAPI browser:
URL:
XML:
The workflow:
Workflow run:
Workflow log:
The result of the tail -f /opt/infra/inframgr/logfile.txt:
Custom Task Code:
importPackage(com.cloupia.model.cIM);
importPackage(java.util);
importPackage(java.lang);
importPackage(java.io);
importPackage(com.cloupia.lib.util);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(org.apache.commons.httpclient);
importPackage(org.apache.commons.httpclient.cookie);
importPackage(org.apache.commons.httpclient.methods);
importPackage(org.apache.commons.httpclient.auth);
importPackage(com.cloupia.model.cEvent.notify);
importPackage(com.cloupia.lib.util.mail);
importPackage(com.cloupia.fw.objstore);
importPackage(com.cloupia.lib.util.managedreports);
var url = input.URL;
var xml = input.XML;
var resp = ctxt.getAPI().userAPIMoCreate(url,xml);
logger.addInfo("Response: "+resp);
output.out1 = resp;
thom.schumacher
Does this workflow expect the VM to be available on VMware?? Or if the VM has been deleted as a result of a Director workflow... Can this be used to force director to remove the entry / rescan and remove if the vm was removed in vmware.
Orf Gelbrich
if you add a disk or RAM to a VM and want to trigger a inventory on the VM vs. vCenter with all its VM's this is the ticket.
