Orf Gelbrich
Task Name
  1. Patch ESXi Servers by vCenter cluster (prepped for firmware upgrade for UCSD 6.6)
Description
  1. .
Prerequisites
  1. Tested on 6.5.0.2 and 6.5.0.1
CategoryWorkflow
ComponentsvSphere 6.5 / Workflow patched to 6.5 Update 1
User Inputs
  8. Click "Submit".
This is meant as and example on how to patch ESXi servers.
Version 1 of the workflow!
If you have better version please post and share with the rest of us.
!!! Note!!!
The patch from VMware has to be in a central location.  In my case I placed it on my datastore (ISO datastore) that is mounted by all my servers.  The file is called update-from-esxi6.5-6.5_update01.zip.
I used this document as a guide: Patching a Standalone ESXi Host
I realize there are many ways to patch, and I choose in version 1.0 of this workflow to do it this way.  I am only dependent on one ssh task and not an array of other tools on other servers.  Yes ssh would have to be enabled to all ESXi servers (There is a task for this as well and could be added to the workflow).
The other item I have hard coded right now it the image that is installed out of the zip file bundle. In my case ESXi-6.5.0-20170702001-standard.
Next version of this workflow these 2 items should be a global workflow variable and replaced in the ssh task with such.
The workflow:
The ESXi patching steps via CLI:
     Test the current version;
          esxcli system version get
     Get the different version from zip file in my case located on my iso datastore
           esxcli software sources profile list --depot="`df -h | sed -n '/ISO/{s/  */ /gp}' | cut -d" " -f6-7`/update-from-esxi6.5-6.5_update01.zip"
     Testing with dry run
          esxcli software profile update --depot="`df -h | sed -n '/ISO/{s/  */ /gp}' | cut -d" " -f6-7`/update-from-esxi6.5-6.5_update01.zip" --dry-run --profile=ESXi-6.5.0-20170702001-standard
     The actual patch
          esxcli software profile update --depot="`df -h | sed -n '/ISO/{s/  */ /gp}' | cut -d" " -f6-7`/update-from-esxi6.5-6.5_update01.zip"  --profile=ESXi-6.5.0-20170702001-standard
     Then a re-boot
          reboot (-f) - this is done via UCSD task
You may wonder why the path for the ISO datastore is not hardcoded.  In my case the datastore on my ESXi servers varies by a number (
/vmfs/volumes/UCSDISOStoreDS246 (7)).  To workaround this I run: df -h | grep -i iso | awk '{print $6" "$7}'
          [root@phorner1:~] df -h | sed -n '/ISO/{s/  */ /gp}' | cut -d" " -f6-7
Workflow Run:
     Note:  I decided to turn off my VM's that are on a ESXi server.  They could also be moved (vMotion Host-to-Host And Cluster-to-Cluster Custom Task v1.0).  Again this is version 1 of the workflow.
I recently patched 32 ESXi servers in 3 hours and the following items I changed:
Copy update-from-esxi6.5-6.5_update01.zip to UCSD into /tmp
Then Copy zip file to datastopres that are common:
scp /tmp/update-from-esxi6.5-6.5_update01.zip root@172.16.33.20:/vmfs/volumes/UCSDRUSTYDC*CL*DSDS*/.
scp /tmp/update-from-esxi6.5-6.5_update01.zip root@172.16.33.28:/vmfs/volumes/UCSDRUSTYDC*CL*DSDS*/.
scp /tmp/update-from-esxi6.5-6.5_update01.zip root@172.16.33.36:/vmfs/volumes/UCSDRUSTYDC*CL*DSDS*/.
scp /tmp/update-from-esxi6.5-6.5_update01.zip root@172.16.33.44:/vmfs/volumes/UCSDRUSTYDC*CL*DSDS*/.
Changed in the ssh task ISO to DSDS
Here is a sub section of the above workflow with a new custom task to figure out the next ESXi server to move the VM's to:
Observer the next ESXi server is picked:
This could be used with with the vMotion task to move VM's to a new ESXi host:
Here is the custom task code:
var LIST = input.List;
var LOOPINDEX = input.LoopIndex;
logger.addInfo("LIST: " + LIST);
logger.addInfo("LOOPINDEX: " + LOOPINDEX)
var array = LIST.split(",");
if(array != null && array.length > 0){
    if(array.length == 1) {
        logger.addInfo("List has only one item. No server to move to!")
    } else {
        for(var i = 0;i<array.length;i++){
            logger.addInfo("List: " + i + " Item: " + array[i])
            if(array[i] == LOOPINDEX){
                if( i+1 < array.length){
                    var NEXTHOST = array[i+1];
                    logger.addInfo("Next Host: " + NEXTHOST);
                    output.ESXiServerToMoveTo = NEXTHOST;
                } else {
                    var NEXTHOST = array[0];
} else {
    logger.addInfo("List was empty!")
This is the next iteration of the above workflow to also upgrade VMware tools on the VM's
It checks this box on each turned off VM:
Workflow run:
The workflow:
