Orf Gelbrich
Task NamePower Shell example on moving a file
Description
  1. Change the user of a running workflow
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
Output
  8. Click "Submit".
The workflow:
User input:   (none)
The task:
This will move a file from 172.17.32.106 to 172.17.32.110 (the UCSD PS Agent)
The script:
echo "net use Y: \\172.17.32.106\Share /Persistent:Yes password@123 /user:baylordemo.local\administrator" > c:\\remcopy.ps1
echo "Copy-Item Y:\\abc.txt.txt c:\\abc.txt" >> c:\\remcopy.ps1
c:\\remcopy.ps1
SQL install
Thank you to Becky and Reuben:
The SR_LOG:
Service Request ID: 5438
Workflow Inputs:
- VMName
Jul 30, 2015 19:54:13 UTC Request submitted
Jul 30, 2015 19:54:17 UTC Executing workflow item number 1
Jul 30, 2015 19:54:17 UTC Completed workflow item number 1, with status Completed
Jul 30, 2015 19:54:20 UTC Executing workflow item number 2
Jul 30, 2015 19:54:20 UTC Trigger context executeWorkFlowStep called
Jul 30, 2015 19:54:21 UTC Executing custom action PowerShellCopyFile (Execute PowerShell Command)
Jul 30, 2015 19:54:24 UTC Max wait time min milli seconds = 300000
Jul 30, 2015 19:54:25 UTC executor finished.....true
Jul 30, 2015 19:54:25 UTC Command Output: <?xml version='1.0'?><Objects />Command successful
Jul 30, 2015 19:54:25 UTC Command executed successfully.
Jul 30, 2015 19:54:25 UTC <?xml version='1.0'?><Objects />Command successful
Jul 30, 2015 19:54:27 UTC Task #1 (PowerShellCopyFile (Execute PowerShell Command)) completed successfully in 6 seconds
Jul 30, 2015 19:54:27 UTC Input/Output values for Task #1 (PowerShellCopyFile (Execute PowerShell Command)):
Jul 30, 2015 19:54:27 UTC [Local Input: Label = Power]
Jul 30, 2015 19:54:27 UTC [Local Input: PowerShell Agent = 172.17.32.110]
Jul 30, 2015 19:54:27 UTC [Local Input: Target Machine IP = 172.17.32.110]
Jul 30, 2015 19:54:27 UTC [Local Input: User ID = administrator]
Jul 30, 2015 19:54:27 UTC [Local Input: Password = **masked-value**]
Jul 30, 2015 19:54:27 UTC [Local Input: Domain = ciscodemo.local]
Jul 30, 2015 19:54:27 UTC [Local Input: Commands/Script = echo 'net use Y: \\172.17.32.106\Share /Persistent:Yes password@123 /user:baylordemo.local\administrator' > c:\\remcopy.ps1 echo 'Copy-Item Y:\\abc.txt.txt c:\\abc.txt' >> c:\\remcopy.ps1 c:\\remcopy.ps1 ]
Jul 30, 2015 19:54:27 UTC [Local Input: Maximum Wait Time = 5]
Jul 30, 2015 19:54:27 UTC [Output: POWERSHELL_COMMAND_RESULT = <?xml version='1.0'?><Objects />Command successful]
Jul 30, 2015 19:54:27 UTC Completed workflow item number 2, with status Completed
The file created:
     The file recopy was created on 172.17.31.110
The file moved:
     The abc file was moved
