Orf Gelbrich
Task NamePower Shell with Roll back
Description
  1. Power Shell with Roll back
Prerequisites
  1. Tested on 5.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Many thanks go out to Mohamed Arif Hajamohideen for providing this new custom task and workflow.
Screen Shot 2014-11-25 at 7.50.53 AM.pngScreen Shot 2014-11-25 at 7.51.02 AM.png
adam.ringenberg
Personal experience:
I used this custom task extensively in my workflows since 5.1. I just upgraded my dev environment from 5.4.0.2 to 5.5.0.0 and I was getting the following error when using this custom task:
{Workflow Step Name}  (custom_Execute Powershell with Rollback) failed with error - java.lang.RuntimeException: java.lang.Exception: Unable to fetch remote agent details, selectedContext=<None>
It took me forever to figure out that the 5.5 Execute Powershell standard task is basically this custom task. Once I copied my settings and script from the custom task into a new standard task everything worked.
Orf Gelbrich
Thank you for sharing.
