Orf Gelbrich
Task NameExample on using the credential policy in concjunction with power shell
Description
Prerequisites
Tested on 5.5
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
The Workflow:
The workflow custom task input:
Mapped Input to the powershell task:
The credential policy used:
The custom task run:
The Custom task to get the credential policy information:
importPackage(com.cloupia.lib.connector.account.credential);
var config = PersistenceUtil.getCredentialPolicyByName(input.CredPolName);
if(config != null){
  logger.addInfo("Credentials retrieved successfully for Credential Account Policy: " + input.credentialPolicyName);
  output.accountUsername = config.getUserName();
  output.accountPassword = config.getPassword();
else{
  logger.addError("Failed to get information for Credential Account Policy: " + input.credentialPolicyName);
  ctxt.setFailed("Failed to get information for Credential Account Policy: " + input.credentialPolicyName);
Thank you Jeff Trumbull for this addition:
Code for dealing with AD accounts in the custom task:
if(config != null){
                var splitAccount = config.getUserName().split("\\")
                if(splitAccount.length == 2){
                                logger.addInfo("User: " + splitAccount[1])
                                logger.addInfo("Domain: " + splitAccount[0])
                                output.accountDomain = splitAccount[0];
                                output.accountUsername = splitAccount[1];
                else{
                                logger.addError("Failed to split domain and username. Verify domain\\username format: " + config.getUserName());
                                ctxt.setFailed("Failed to split domain and username. Verify domain\\username format: " + config.getUserName());
else{
