Orf Gelbrich
Task NameRetrieve the content of a variable that was used in a SR record execution
Description
Prerequisites
Minimum UCSD version: 5.4.0.1
CategoryCustom task
Components
User Inputs
User OutputVariable Content
  8. Click "Submit".
Thank you goes to:  Niraj Kumar
Workflow execution:
Workflow Log:
phirobin
Community Member
Hey Orf - thanks for this - but How do we reference an output in a compound task within the workflow?
Phil
Orf Gelbrich
You need to map it in the task to a global workflow output variable:
