Orf Gelbrich
Task Name
This workflow will get from a VM ID the VM Domain Name defined in a VDC Service Delivery Policy
Description
Prerequisites
Tested on UCSD 6.0.1.0 and 6.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
The Log:
Service Request ID: 227
Workflow Inputs:
- color
Mar 01, 2017 22:47:51 UTC Request submitted
Mar 01, 2017 22:47:52 UTC Executing workflow item number 1
Mar 01, 2017 22:47:52 UTC Completed workflow item number 1, with status Completed
Mar 01, 2017 22:47:58 UTC Executing workflow item number 2
Mar 01, 2017 22:47:58 UTC Trigger context executeWorkFlowStep called
Mar 01, 2017 22:47:58 UTC Executing custom action GetMyDomain (custom_getVMSummary)
Mar 01, 2017 22:47:58 UTC Executing custom action GetMyDomain (custom_getVMSummary) for VM 44 (vm-SR188)
Mar 01, 2017 22:47:58 UTC Executing custom script for getVMSummary
Mar 01, 2017 22:47:58 UTC vmId = 44
Mar 01, 2017 22:47:58 UTC Overview_VM_ID = 44
Mar 01, 2017 22:47:58 UTC Overview_Instance_Name = vm-SR188
Mar 01, 2017 22:47:58 UTC Overview_Status = ON (poweredOn)
Mar 01, 2017 22:47:58 UTC Overview_IP_Address =
Mar 01, 2017 22:47:58 UTC Overview_Hostname = null
Mar 01, 2017 22:47:58 UTC Overview_Image_ID = vm-SR188
Mar 01, 2017 22:47:58 UTC Overview_Cloud_Name = Dallas110
Mar 01, 2017 22:47:58 UTC Overview_Cloud_Type = VMWare
Mar 01, 2017 22:47:58 UTC Ownership_Group = developer
Mar 01, 2017 22:47:58 UTC Ownership_vDC = VDC_Dallas_Prod
Mar 01, 2017 22:47:58 UTC Ownership_Category = Generic VM
Mar 01, 2017 22:47:58 UTC Ownership_Service_Request_ID = 188
Mar 01, 2017 22:47:58 UTC Ownership_Label = CallManager1
Mar 01, 2017 22:47:58 UTC Ownership_Provisioned_Time = Feb 20, 2017 16:22:57 UTC
Mar 01, 2017 22:47:58 UTC Ownership_Scheduled_Termination_Time =
Mar 01, 2017 22:47:58 UTC Overview_Host_Node = 172.17.32.113
Mar 01, 2017 22:47:58 UTC Network_Port_Group = VM Network
Mar 01, 2017 22:47:58 UTC Network_VLAN_ID = 0
Mar 01, 2017 22:47:58 UTC Network_No_of_vNics = 1
Mar 01, 2017 22:47:58 UTC Network_vNic_Mac_Address = 00:50:56:94:11:62
Mar 01, 2017 22:47:58 UTC Network_vNic_Device_Config_Id = 4000
Mar 01, 2017 22:47:58 UTC Overview_Boot_Time = Feb 20, 2017 16:41:35 UTC
Mar 01, 2017 22:47:58 UTC Overview_Config_Name = vm-SR188
Mar 01, 2017 22:47:58 UTC Overview_VM_Version = vmx-08
Mar 01, 2017 22:47:58 UTC Resources_Resource_Pool = Class_Pool_1
Mar 01, 2017 22:47:58 UTC Resources_Num_Virtual_CPUs = 1
Mar 01, 2017 22:47:58 UTC Resources_CPU_Reserved_MHz = 0
Mar 01, 2017 22:47:58 UTC Resources_CPU_Limit_MHz = -1
Mar 01, 2017 22:47:58 UTC Resources_CPU_Overhead_Limit_MHz = 0
Mar 01, 2017 22:47:58 UTC Resources_CPU_Shares = 1000
Mar 01, 2017 22:47:58 UTC Resources_Memory_MB = 2048
Mar 01, 2017 22:47:58 UTC Resources_Memory_Reserved_MB = 2048
Mar 01, 2017 22:47:58 UTC Resources_Memory_Limit_MB = 0
Mar 01, 2017 22:47:58 UTC Resources_Memory_Overhead_Limit_MB = 58
Mar 01, 2017 22:47:58 UTC Resources_Memory_Shares = 20480
Mar 01, 2017 22:47:58 UTC Storage_Total_Provisioned_GB = 110.04
Mar 01, 2017 22:47:58 UTC Storage_Committed_GB = 110.04
Mar 01, 2017 22:47:58 UTC Storage_Uncommitted_GB = 0
Mar 01, 2017 22:47:58 UTC Storage_Non_shared_GB = 110.04
Mar 01, 2017 22:47:58 UTC Storage_Data_Store_Names = SAN1
Mar 01, 2017 22:47:58 UTC Storage_VM_Path = [SAN1] vm-SR188/vm-SR188.vmx
Mar 01, 2017 22:47:58 UTC Guest_Information_Guest_OS = Red Hat Enterprise Linux 6 (64-bit)
Mar 01, 2017 22:47:58 UTC Guest_Information_Guest_State = notRunning
Mar 01, 2017 22:47:58 UTC Guest_Information_Tools_Status = guestToolsNotRunning
Mar 01, 2017 22:47:58 UTC Guest_Information_Tools_Version = 0
Mar 01, 2017 22:47:58 UTC Options_Default_PowerOff_Type = soft
Mar 01, 2017 22:47:58 UTC Processing output: Overview_VM_ID
Mar 01, 2017 22:47:58 UTC Processing output: Overview_Instance_Name
Mar 01, 2017 22:47:58 UTC Processing output: Overview_Status
Mar 01, 2017 22:47:58 UTC Processing output: Overview_IP_Address
Mar 01, 2017 22:47:58 UTC Processing output: Overview_Hostname
Mar 01, 2017 22:47:58 UTC output: Overview_Hostname is not set
Mar 01, 2017 22:47:58 UTC Processing output: Overview_Image_ID
Mar 01, 2017 22:47:59 UTC Processing output: Overview_Cloud_Name
Mar 01, 2017 22:47:59 UTC Processing output: Overview_Cloud_Type
Mar 01, 2017 22:47:59 UTC Processing output: Ownership_Group
Mar 01, 2017 22:47:59 UTC Processing output: Ownership_vDC
Mar 01, 2017 22:47:59 UTC Processing output: Ownership_Category
Mar 01, 2017 22:47:59 UTC Processing output: Ownership_Service_Request_ID
Mar 01, 2017 22:47:59 UTC Processing output: Ownership_Label
Mar 01, 2017 22:47:59 UTC Processing output: Ownership_Provisioned_Time
Mar 01, 2017 22:47:59 UTC Processing output: Ownership_Scheduled_Termination_Time
Mar 01, 2017 22:47:59 UTC Processing output: Overview_Host_Node
Mar 01, 2017 22:47:59 UTC Processing output: Network_Port_Group
Mar 01, 2017 22:47:59 UTC Processing output: Network_VLAN_ID
Mar 01, 2017 22:47:59 UTC Processing output: Network_No_of_vNics
Mar 01, 2017 22:47:59 UTC Processing output: Network_vNic_Mac_Address
Mar 01, 2017 22:47:59 UTC Processing output: Network_vNic_Device_Config_Id
Mar 01, 2017 22:47:59 UTC Processing output: Overview_Boot_Time
Mar 01, 2017 22:47:59 UTC Processing output: Overview_Config_Name
Mar 01, 2017 22:47:59 UTC Processing output: Overview_VM_Version
Mar 01, 2017 22:47:59 UTC Processing output: Resources_Resource_Pool
Mar 01, 2017 22:47:59 UTC Processing output: Resources_Num_Virtual_CPUs
Mar 01, 2017 22:47:59 UTC Processing output: Resources_CPU_Reserved_MHz
Mar 01, 2017 22:47:59 UTC Processing output: Resources_CPU_Limit_MHz
Mar 01, 2017 22:47:59 UTC Processing output: Resources_CPU_Overhead_Limit_MHz
Mar 01, 2017 22:47:59 UTC Processing output: Resources_CPU_Shares
Mar 01, 2017 22:47:59 UTC Processing output: Resources_Memory_MB
Mar 01, 2017 22:47:59 UTC Processing output: Resources_Memory_Reserved_MB
Mar 01, 2017 22:48:00 UTC Processing output: Resources_Memory_Limit_MB
Mar 01, 2017 22:48:00 UTC Processing output: Resources_Memory_Overhead_Limit_MB
Mar 01, 2017 22:48:00 UTC Processing output: Resources_Memory_Shares
Mar 01, 2017 22:48:00 UTC Processing output: Storage_Total_Provisioned_GB
Mar 01, 2017 22:48:00 UTC Processing output: Storage_Committed_GB
Mar 01, 2017 22:48:00 UTC Processing output: Storage_Uncommitted_GB
Mar 01, 2017 22:48:00 UTC Processing output: Storage_Non_shared_GB
Mar 01, 2017 22:48:00 UTC Processing output: Storage_Data_Store_Names
Mar 01, 2017 22:48:00 UTC Processing output: Storage_VM_Path
Mar 01, 2017 22:48:00 UTC Processing output: Guest_Information_Guest_OS
Mar 01, 2017 22:48:00 UTC Processing output: Guest_Information_Guest_State
Mar 01, 2017 22:48:00 UTC Processing output: Guest_Information_Tools_Status
Mar 01, 2017 22:48:00 UTC Processing output: Guest_Information_Tools_Version
Mar 01, 2017 22:48:00 UTC Processing output: Options_Default_PowerOff_Type
Mar 01, 2017 22:48:00 UTC Task #2 (GetMyDomain (custom_getVMSummary)) completed successfully in 2 seconds
Mar 01, 2017 22:48:00 UTC Input/Output values for Task #2 (GetMyDomain (custom_getVMSummary)):
Mar 01, 2017 22:48:00 UTC [Template Input:VM_Id = ${VM_ID}]
Mar 01, 2017 22:48:00 UTC [Resolved Template Input: VM_Id = 44]
Mar 01, 2017 22:48:00 UTC [Local Input: VM_Id = 44]
Mar 01, 2017 22:48:00 UTC [Output: Overview_VM_ID = 44]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Instance_Name = vm-SR188]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Status = ON (poweredOn)]
Mar 01, 2017 22:48:00 UTC [Output: Overview_IP_Address = ]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Image_ID = vm-SR188]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Cloud_Name = Dallas110]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Cloud_Type = VMWare]
Mar 01, 2017 22:48:00 UTC [Output: Ownership_Group = developer]
Mar 01, 2017 22:48:00 UTC [Output: Ownership_vDC = VDC_Dallas_Prod]
Mar 01, 2017 22:48:00 UTC [Output: Ownership_Category = Generic VM]
Mar 01, 2017 22:48:00 UTC [Output: Ownership_Service_Request_ID = 188]
Mar 01, 2017 22:48:00 UTC [Output: Ownership_Label = CallManager1]
Mar 01, 2017 22:48:00 UTC [Output: Ownership_Provisioned_Time = Feb 20, 2017 16:22:57 UTC]
Mar 01, 2017 22:48:00 UTC [Output: Ownership_Scheduled_Termination_Time = ]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Host_Node = 172.17.32.113]
Mar 01, 2017 22:48:00 UTC [Output: Network_Port_Group = VM Network]
Mar 01, 2017 22:48:00 UTC [Output: Network_VLAN_ID = 0]
Mar 01, 2017 22:48:00 UTC [Output: Network_No_of_vNics = 1]
Mar 01, 2017 22:48:00 UTC [Output: Network_vNic_Mac_Address = 00:50:56:94:11:62]
Mar 01, 2017 22:48:00 UTC [Output: Network_vNic_Device_Config_Id = 4000]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Boot_Time = Feb 20, 2017 16:41:35 UTC]
Mar 01, 2017 22:48:00 UTC [Output: Overview_Config_Name = vm-SR188]
Mar 01, 2017 22:48:00 UTC [Output: Overview_VM_Version = vmx-08]
Mar 01, 2017 22:48:00 UTC [Output: Resources_Resource_Pool = Class_Pool_1]
Mar 01, 2017 22:48:00 UTC [Output: Resources_Num_Virtual_CPUs = 1]
Mar 01, 2017 22:48:00 UTC [Output: Resources_CPU_Reserved_MHz = 0]
Mar 01, 2017 22:48:00 UTC [Output: Resources_CPU_Limit_MHz = -1]
Mar 01, 2017 22:48:00 UTC [Output: Resources_CPU_Overhead_Limit_MHz = 0]
Mar 01, 2017 22:48:00 UTC [Output: Resources_CPU_Shares = 1000]
Mar 01, 2017 22:48:00 UTC [Output: Resources_Memory_MB = 2048]
Mar 01, 2017 22:48:00 UTC [Output: Resources_Memory_Reserved_MB = 2048]
Mar 01, 2017 22:48:00 UTC [Output: Resources_Memory_Limit_MB = 0]
Mar 01, 2017 22:48:00 UTC [Output: Resources_Memory_Overhead_Limit_MB = 58]
Mar 01, 2017 22:48:00 UTC [Output: Resources_Memory_Shares = 20480]
Mar 01, 2017 22:48:00 UTC [Output: Storage_Total_Provisioned_GB = 110.04]
Mar 01, 2017 22:48:00 UTC [Output: Storage_Committed_GB = 110.04]
Mar 01, 2017 22:48:00 UTC [Output: Storage_Uncommitted_GB = 0]
Mar 01, 2017 22:48:00 UTC [Output: Storage_Non_shared_GB = 110.04]
Mar 01, 2017 22:48:00 UTC [Output: Storage_Data_Store_Names = SAN1]
Mar 01, 2017 22:48:00 UTC [Output: Storage_VM_Path = [SAN1] vm-SR188/vm-SR188.vmx]
Mar 01, 2017 22:48:00 UTC [Output: Guest_Information_Guest_OS = Red Hat Enterprise Linux 6 (64-bit)]
Mar 01, 2017 22:48:00 UTC [Output: Guest_Information_Guest_State = notRunning]
Mar 01, 2017 22:48:00 UTC [Output: Guest_Information_Tools_Status = guestToolsNotRunning]
Mar 01, 2017 22:48:00 UTC [Output: Guest_Information_Tools_Version = 0]
Mar 01, 2017 22:48:00 UTC [Output: Options_Default_PowerOff_Type = soft]
Mar 01, 2017 22:48:00 UTC Completed workflow item number 2, with status Completed
Mar 01, 2017 22:48:04 UTC Executing workflow item number 3
Mar 01, 2017 22:48:04 UTC Trigger context executeWorkFlowStep called
Mar 01, 2017 22:48:04 UTC Executing custom action GetMyDomain (custom_VDC_Name_2_VDC_ID)
Mar 01, 2017 22:48:04 UTC Executing custom action GetMyDomain (custom_VDC_Name_2_VDC_ID) for VM 44 (vm-SR188)
Mar 01, 2017 22:48:04 UTC Executing custom script for VDC_Name_2_VDC_ID
Mar 01, 2017 22:48:09 UTC vdc networkPolicyReport = com.cloupia.model.cIM.APITabularReport@61d27d98
Mar 01, 2017 22:48:09 UTC policyList = [{vDC_ID=2, vDC_Name=VDC_Dallas_Prod, Type=Standard, vDC_Description=, Cloud=Dallas110, Group=developer, Approver_1=, Approver_2=, Status=OK}]
Mar 01, 2017 22:48:09 UTC VDC_ID = null
Mar 01, 2017 22:48:09 UTC VDC_ID = 2
Mar 01, 2017 22:48:09 UTC Processing output: VDC_ID
Mar 01, 2017 22:48:09 UTC Task #3 (GetMyDomain (custom_VDC_Name_2_VDC_ID)) completed successfully in 5 seconds
Mar 01, 2017 22:48:09 UTC Input/Output values for Task #3 (GetMyDomain (custom_VDC_Name_2_VDC_ID)):
Mar 01, 2017 22:48:09 UTC [Mapped Input: VDC_Name = VDC_Dallas_Prod]
Mar 01, 2017 22:48:09 UTC [Output: VDC_ID = 2]
Mar 01, 2017 22:48:09 UTC Completed workflow item number 3, with status Completed
Mar 01, 2017 22:48:10 UTC Executing workflow item number 4
Mar 01, 2017 22:48:10 UTC Trigger context executeWorkFlowStep called
Mar 01, 2017 22:48:10 UTC Executing custom action GetMyDomain (custom_Get_VDC_POLICIES)
Mar 01, 2017 22:48:10 UTC Executing custom action GetMyDomain (custom_Get_VDC_POLICIES) for VM 44 (vm-SR188)
Mar 01, 2017 22:48:10 UTC Executing custom script for Get_VDC_POLICIES
Mar 01, 2017 22:48:10 UTC vdc networkPolicy = DallasProd
Mar 01, 2017 22:48:10 UTC vdc getUserActionsPolicy = My Application
Mar 01, 2017 22:48:10 UTC vdc getComputingPolicy = DallasProdCompute1
Mar 01, 2017 22:48:10 UTC vdc getStoragePolicy = DallasProd
Mar 01, 2017 22:48:10 UTC vdc getCostModel = Gold
Mar 01, 2017 22:48:10 UTC vdc getVdcDescription = null
Mar 01, 2017 22:48:10 UTC vdc getPrimaryDeployPolicy = DallasProd1
Mar 01, 2017 22:48:10 UTC Processing output: out1
Mar 01, 2017 22:48:10 UTC Task #4 (GetMyDomain (custom_Get_VDC_POLICIES)) completed successfully in 0 seconds
Mar 01, 2017 22:48:10 UTC Input/Output values for Task #4 (GetMyDomain (custom_Get_VDC_POLICIES)):
Mar 01, 2017 22:48:10 UTC [Mapped Input: VDC_ID = 2]
Mar 01, 2017 22:48:10 UTC [Output: out1 = DallasProd1]
Mar 01, 2017 22:48:10 UTC Completed workflow item number 4, with status Completed
Mar 01, 2017 22:48:16 UTC Executing workflow item number 5
Mar 01, 2017 22:48:16 UTC Trigger context executeWorkFlowStep called
Mar 01, 2017 22:48:16 UTC Executing custom action GetMyDomain (custom_Generic_Report)
Mar 01, 2017 22:48:16 UTC Executing custom action GetMyDomain (custom_Generic_Report) for VM 44 (vm-SR188)
Mar 01, 2017 22:48:16 UTC Executing custom script for Generic_Report
Mar 01, 2017 22:48:16 UTC -------------------------------------
Mar 01, 2017 22:48:16 UTC Iteration : 0
Mar 01, 2017 22:48:16 UTC Col1 : 1
Mar 01, 2017 22:48:16 UTC Col2 : DallasProd1
Mar 01, 2017 22:48:16 UTC Col3 :
Mar 01, 2017 22:48:16 UTC Col4 : null
Mar 01, 2017 22:48:16 UTC Col5 : ${VMNAME}
Mar 01, 2017 22:48:16 UTC Col6 : ciscodemo.local
Mar 01, 2017 22:48:16 UTC Col7 : null
Mar 01, 2017 22:48:16 UTC Looking for SearchValue1...............: DallasProd1
Mar 01, 2017 22:48:16 UTC Comparing too...............: DallasProd1
Mar 01, 2017 22:48:16 UTC Found..............: ciscodemo.local
Mar 01, 2017 22:48:16 UTC Processing output: ReturnStatus
Mar 01, 2017 22:48:16 UTC Processing output: c1
Mar 01, 2017 22:48:16 UTC Processing output: c2
Mar 01, 2017 22:48:16 UTC Processing output: c3
Mar 01, 2017 22:48:16 UTC Processing output: c4
Mar 01, 2017 22:48:16 UTC output: c4 is not set
Mar 01, 2017 22:48:16 UTC Processing output: c5
Mar 01, 2017 22:48:16 UTC Processing output: c6
Mar 01, 2017 22:48:16 UTC Processing output: c7
Mar 01, 2017 22:48:16 UTC output: c7 is not set
Mar 01, 2017 22:48:16 UTC Task #5 (GetMyDomain (custom_Generic_Report)) completed successfully in 0 seconds
Mar 01, 2017 22:48:16 UTC Input/Output values for Task #5 (GetMyDomain (custom_Generic_Report)):
Mar 01, 2017 22:48:16 UTC [Local Input: ContextSelector = global_admin]
Mar 01, 2017 22:48:16 UTC [Local Input: NonGlobalContextSelector = ]
Mar 01, 2017 22:48:16 UTC [Local Input: ReportLabel = PolicyFeature.report.private.system.dep.config]
Mar 01, 2017 22:48:16 UTC [Local Input: Col1 = Policy ID]
Mar 01, 2017 22:48:16 UTC [Local Input: Col2 = Policy Name]
Mar 01, 2017 22:48:16 UTC [Local Input: Col3 = Policy Description]
Mar 01, 2017 22:48:16 UTC [Local Input: Col4 = Power ON?]
Mar 01, 2017 22:48:16 UTC [Local Input: Col5 = Host Name Template]
Mar 01, 2017 22:48:16 UTC [Local Input: Col6 = DNS Domain]
Mar 01, 2017 22:48:16 UTC [Local Input: Col7 = ]
Mar 01, 2017 22:48:16 UTC [Local Input: SearchColumn = Policy Name]
Mar 01, 2017 22:48:16 UTC [Mapped Input: SearchValue = DallasProd1]
Mar 01, 2017 22:48:16 UTC [Output: ReturnStatus = 0]
Mar 01, 2017 22:48:17 UTC [Output: c1 = 1]
Mar 01, 2017 22:48:17 UTC [Output: c2 = DallasProd1]
Mar 01, 2017 22:48:17 UTC [Output: c3 = ]
Mar 01, 2017 22:48:17 UTC [Output: c5 = ${VMNAME}]
Mar 01, 2017 22:48:17 UTC [Output: c6 = ciscodemo.local]
Mar 01, 2017 22:48:17 UTC Completed workflow item number 5, with status Completed
Mar 01, 2017 22:48:22 UTC Executing workflow item number 6
Mar 01, 2017 22:48:22 UTC Trigger context executeWorkFlowStep called
Mar 01, 2017 22:48:22 UTC Executing custom action GetMyDomain (custom_SR_LOG_FILE_ENTRY)
Mar 01, 2017 22:48:22 UTC Executing custom action GetMyDomain (custom_SR_LOG_FILE_ENTRY) for VM 44 (vm-SR188)
Mar 01, 2017 22:48:22 UTC Executing custom script for SR_LOG_FILE_ENTRY
Mar 01, 2017 22:48:22 UTC ciscodemo.local
Mar 01, 2017 22:48:22 UTC Task #6 (GetMyDomain (custom_SR_LOG_FILE_ENTRY)) completed successfully in 0 seconds
Mar 01, 2017 22:48:22 UTC Input/Output values for Task #6 (GetMyDomain (custom_SR_LOG_FILE_ENTRY)):
Mar 01, 2017 22:48:22 UTC [Mapped Input: Message = ciscodemo.local]
Mar 01, 2017 22:48:22 UTC [Mapped Input: Error_color = 2]
Mar 01, 2017 22:48:22 UTC Completed workflow item number 6, with status Completed
Mar 01, 2017 22:48:25 UTC Executing workflow item number 7
Mar 01, 2017 22:48:25 UTC Completed workflow item number 7, with status Completed
