markpsmi
Attached is an example of Python script that calls UCSD northbound Web Services API. This has been tested with Python 2.7 and UCSD 5.2. The example show how to execute a Workflow in UCSD.
Here is the Script:
import urllib2
import json
import time
ip_addr = "10.95.4.23"
username = "admin"
password = "admin"
workflowName = "DeployESXi"
def getApiKey (ip_addr, username, password):
    ip_addr = ip_addr
    username = username
    password = password
    url = 'http://'+ip_addr+'/app/api/rest?formatType=json&opName=getRESTKey&user='+username+'&password='+password
    # This packages the request (it doesn't make it)
    request = urllib2.Request(url=url)
    # Sends the request and catches the response
    response = urllib2.urlopen(request)
    return response.read().replace("\"", "")
apiKey = getApiKey(ip_addr, username, password)
url = 'http://'+ip_addr+'/app/api/rest?formatType=json&opName=userAPIGetMyLoginProfile&opData={}'
request = urllib2.Request(url=url, headers={"X-Cloupia-Request-Key" : apiKey})
print response.read()
#######Execute a workflow#######
url = 'http://'+ip_addr+'/app/api/rest?formatType=json&opName=userAPISubmitWorkflowServiceRequest&opData={param0:"DeployESXi",param1:{"list":[{"name":"Hostname","value":"Nike"}]},param2:-1}'
j = json.loads(response.read())
serviceRequest = j['serviceResult']
print serviceRequest
######Check for completion######
flag = 0
while flag == 0:
    time.sleep(30)
    url = 'http://'+ip_addr+'/app/api/rest?formatType=json&opName=userAPIGetWorkflowStatus&opData={param0:'+str(serviceRequest)+'}'
    status = j['serviceResult']
    if status == 1:
        print "Workflow "+workflowName+" with SR ID "+str(serviceRequest)+" is In Progress"
    elif status == 3:
        print "Workflow "+workflowName+" with SR ID "+str(serviceRequest)+" is Complete"
        flag = 1
    elif status == 2:
        print "Workflow "+workflowName+" with SR ID "+str(serviceRequest)+" Failed"
        flag = 1
