AIM-CUE CF Card Issue
gohlex8848
Hi Guys,
Hope someone can assist me on the following issue.
I've an AIM-CUE module which one day after the power cycle, I got the following error during the module boot up.
"Not a cisco supported CF. Please use cisco supported CF and reinstall the software."
Understand my CF card could be toasted as it can't even detected by the card reader.
I've hence doing some google and saw the original AIM-CUE-1GBCF= cost even more than the module itself.
then someone mentioned an CF card with 2001888 sectors could be a cheaper replacement.
I've success to found two 1GB CF card with the same sector (one of it is cisco router mem cf 1gb), and since have a chance to borrow the other working AIM-CUE CF card on hand, I've used fedora core 15 and "DDed" the working CF to an Image with the following command
"dd if=/dev/sdb of=/image bs=32768"
and write the image to the two card that i've bought, but guess what i've not gotten any luck on this.
Still after using the bootloader to initialize the module, i still getting the "not a cisco supported CF" error.
By any chance anyone sucessfully to run AIM-CUE on other CF card that can shed some light?
P/S I'm using this module for my CCIE lab preparation, and it is a used unit, hence there isn't anyway I could do RMA : (
Alex
are.
gohlex8848
Any kind soul able to help?
HEy I know this is old, but were you able to solve this ? I have a AIM-CUE module that doesnt have a CF card and buying the CF card would be more expensive then the CUE it self. SO I`m looking at the alternativies...
this post would help you
https://supportforums.cisco.com/discussion/10638601/aim-cue-and-compactflash-memory
best regards
had a great day . best regards, and rate if you'll find this post useful
