04-27-2004 01:38 PM - edited 03-18-2019 02:56 PM
-- Or importing a user from Active Directory using the System Admin under subcriber.
Currently when you import a user, the DTMF ID is derived from the Telephone Number feild under the General Tab of AD. Is there a way to use an alternative feild? For example the IP phone feild under the Telephones Tab of AD.
Our company already uses the telephone tab and all of them are not in the correct syntax (ex 312-395-2718).
04-27-2004 02:20 PM
no, CUBI isn't sophisticated enough to let you pick another field in AD (or Ex55 or Domino) to pull that information from - it also can't just grab the rightmost X digits from the business phone field which would also be nice.
As usual with items like this, please ask your account teams to open a PERs for you so the DB boys know this is something that folks in the field would like to do - without field requests items like that don't get on the development plate.
04-29-2007 07:30 PM
Has there been any changes to this? it appears that CUBI still works the same way. I would like to use the IP Telephone field in AD for the DTMF ID.
