Anwar
anwar.signals1
Dear Fello. I am trying to deploy UCM Cisco Jabber. Where can I get deployment guideline. Please guide me. Regards
Jaime Valencia
This is very easy to get from cisco.com, or simply by using google to get the docs
cisco.com -> Support -> All Products
Then either:
a) use the decision tree to look for the product
b) click the "Select a Product" drop down, scroll for the product, or type in the name of the product
If you do the above for Jabber for Windows, you get to this page:
http://www.cisco.com/c/en/us/support/unified-communications/jabber-windows/tsd-products-support-series-home.html
The above method works for any product, you should have no problems finding the main documentation page for any product in the future.
java
if this helps, please rate
