Asterisk as Voicemail for Cisco Call manger
rbblue234
Hi All,
I'm currently getting SIP/2.0 500 Internal Server Error when trying to turn on MWI.   Currently the cisco call manager is able to forward calls into asterisk for RNA, for CFA to VM. If the user hits the messages key, they are routed over to asterisk and asked for their password. Everything appears to be okay and working except for MWI.  When asterisk tries to dial the MWI number, CUCM is providing a SIP/2.0 500 Internal Server Error response.
The VoIP phone extension is 314.  The MWI turn on number is 880.  Asterisk IP is 192.168.10.51 and CUCM IP is 192.168.10.49.  Again, All call routing works..  As in if asterisk hands a PSTN call to CUCM, it will accept the call and route to the correct VoIP phone for answer. If no one answers that phone, the call is redirected back to asterisk for Voicemail.
sip_additional.conf
[cucmIN]
disallow=all
type=friend
context=sccp
host=192.168.10.49
allow=ulaw
allow=g729
nat=no
canreinvite=yes
qualify=yes
[cucmOut]
disallow=all
host=192.168.10.49
type=friend
allow=ulaw
allow=g729
nat=no
canreinvite=yes
qualify=yes
context=from-trunk-sip-cucmOut
extensions_customer.conf
[sccp]
include => ext-local
include => outbound-allroutes
include => app-vmmain
include => ext-featurecodes
include => ext-queues
include => Cisco-Voicemail
include => ciscovmail
[Cisco-Voicemail]
exten => 88808,1,GotoIf(${MAILBOX_EXISTS(${CALLERID(num)}@ciscovmail)} = "1"?400)
exten => 88808,2,Voicemail(${CALLERID(RDNIS)}@ciscovmail,u)
exten => 88808,3,Playback(vm-goodbye)
exten => 88808,4,Hangup
exten => 88808,400,VoicemailMain(${CALLERID(num)}@ciscovmail)
[ciscovmail]
exten => _280XXX,1,SetCallerID(${EXTEN:3})
exten => _280XXX,2,Dial(SIP/881@192.168.10.49)
exten => _280XXX,3,Answer
exten => _280XXX,4,Wait,1
exten => _280XXX,5,Hangup
exten => _281XXX,1,SetCallerID(${EXTEN:3})
exten => _281XXX,2,Dial(SIP/880@192.168.10.49)
exten => _281XXX,3,Answer
exten => _281XXX,4,Wait,1
exten => _281XXX,5,Hangup
Sip Debug
[2013-06-29 08:48:57] WARNING[31860]: pbx_spool.c:297 safe_append: Unable to set utime on /var/spool/asterisk/outgoing/mwion.call.x1GJ102r: Operation not permitted
    -- Attempting call on SIP/880@cucmOut for 314@from-sip:2 (Retry 1)
  == Using SIP RTP TOS bits 184
  == Using SIP RTP CoS mark 5
Audio is at 13798
Adding codec 0x4 (ulaw) to SDP
Adding non-codec 0x1 (telephone-event) to SDP
Reliably Transmitting (no NAT) to 192.168.10.49:5060:
INVITE sip:880@192.168.10.49 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.51:5060;branch=z9hG4bK5bf64f67
Max-Forwards: 70
From: "VoiceMail" <sip:314@192.168.10.51>;tag=as66a9cb2f
To: <sip:880@192.168.10.49>
Contact: <sip:314@192.168.10.51:5060>
Call-ID: 6ec8be502fc1fc1606c6fe491a635c37@192.168.10.51:5060
CSeq: 102 INVITE
User-Agent: FPBX-2.10.1(1.8.21.0)
Date: Sat, 29 Jun 2013 12:48:57 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Content-Type: application/sdp
Content-Length: 237
v=0
o=root 109490670 109490670 IN IP4 192.168.10.51
s=Asterisk PBX 1.8.21.0
c=IN IP4 192.168.10.51
t=0 0
m=audio 13798 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
<--- SIP read from UDP:192.168.10.49:5060 --->
SIP/2.0 100 Trying
Allow-Events: presence
Content-Length: 0
CSeq: 102 INVITE
--- (9 headers 0 lines) ---
Content-Length: 0
To: <sip:880@192.168.10.49>;tag=ed20608f-032f-4323-ac4c-650fe15afd77-19794265
CSeq: 102 INVITE
    -- Got SIP response 500 "Internal Server Error" back from 192.168.10.49:5060
ACK sip:880@192.168.10.49 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
[2013-06-29 08:48:57] NOTICE[4291]: pbx_spool.c:372 attempt_thread: Call failed to go through, reason (8) Congestion (circuits busy)
[2013-06-29 08:48:57] NOTICE[4291]: pbx_spool.c:375 attempt_thread: Queued call to SIP/880@cucmOut expired without completion after 0 attempts
Really destroying SIP dialog '6ec8be502fc1fc1606c6fe491a635c37@192.168.10.51:5060' Method: INVITE
    -- SEP000821969E93: unknown: 0, active call? no
    -- SEP000821969E93: Sending phone a token rejection (sccp.conf:fallback=false), ask again in '60' seconds
Tommer Catlin
CUCM can accept unsolicated MWI requests from outside vendors.  For example, Exchange 2010 and above, you can MWI lights sent over the SIP trunk with no codes.  Unless Asterisk does not support unsolicated MWI requests?
HI!
Thanks for the respone.  Asterisk is the acting as the voicemail server here.  Asterisk is trying to light the MWI light on the phone which is attached to CUCM.   When asterisk makes the call to the CUCM MWI on light, we are getting a 500 internal error code.
I sinced changed the MWI on light to be 7880 (in an effort to move the MWI to something 100% out of the normal dial plan) and recieve the same results.  I enabled CUCM traces and pulled the following.    Any idea?  Again..  This is a sip call from asterisk @ 192.168.10.51 to CUCM 7.1.5 @ 192.168.10.49.  The caller ID was rewritten to 314 which is the extension of the phone, and call is being placed to 7880 which is MWI on extension.
|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:20000>
07/01/2013 13:06:20.984 CCM|//SIP/Stack/States/0xebe3248/0xebe3248 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:40000>
07/01/2013 13:06:31.708 CCM|//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 814 from 192.168.10.51:[5060]:
INVITE sip:7880@192.168.10.49 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.51:5060;branch=z9hG4bK5f3ccdf7
Max-Forwards: 70
To: <7880>
Contact: <314>
Call-ID: 79b657c759f521d62ac821d84e449368@192.168.10.51:5060
CSeq: 102 INVITE
Date: Mon, 01 Jul 2013 20:06:31 GMT
Content-Length: 259
v=0
o=root 67849568 67849568 IN IP4 192.168.10.51
t=0 0
m=audio 16744 RTP/AVP 0 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
07/01/2013 13:06:31.708 CCM|//SIP/Stack/States/0xebe1610/0xebe1610 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:40000>
07/01/2013 13:06:31.709 CCM|//SIP/Stack/States/0xebe1610/0xebe1610 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:40000>
07/01/2013 13:06:31.709 CCM|DbMobility: can't find remdest 314 in map|<:STANDALONECLUSTER><:192.168.10.49><:ERROR><:FFFFFF>
07/01/2013 13:06:31.710 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 192.168.10.51:[5060]:
SIP/2.0 100 Trying
Content-Length: 0
To: <7880>
CSeq: 102 INVITE
07/01/2013 13:06:31.710 CCM|DbMobility: can't find remdest 314 in map|<:STANDALONECLUSTER><:192.168.10.49><:ERROR><:FFFFFF>
07/01/2013 13:06:31.711 CCM|Digit Analysis: getDaRes - voiceMailCallingSearchSpace=[]|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:0800>
07/01/2013 13:06:31.711 CCM|Digit analysis: match(pi="2", fqcn="", cn="314",plv="5", pss="RRG", TodFilteredPss="RRG", dd="7880",dac="0")|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:0800>
07/01/2013 13:06:31.711 CCM|Digit analysis: analysis results|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:0800>
07/01/2013 13:06:31.712 CCM||PretransformCallingPartyNumber=314
|DialingPartition=RRG
|DialingPattern=7880
|FullyQualifiedCalledPartyNumber=7880
|DialingPatternRegularExpression=(7880)
|DialingWhere=
|PatternType=Enterprise
|PotentialMatches=NoPotentialMatchesExist
|DialingSdlProcessId=(0,0,0)
|PretransformDigitString=7880
|PretransformTagsList=SUBSCRIBER
|PretransformPositionalMatchList=7880
|CollectedDigits=7880
|UnconsumedDigits=
|TagsList=SUBSCRIBER
|VoiceMailbox=
|VoiceMailCallingSearchSpace=
|VoiceMailPilotNumber=
|RouteBlockFlag=BlockThisPattern
|RouteBlockCause=0
|AlertingName=
|UnicodeDisplayName=
|DisplayNameLocale=1
|InterceptPartition=RRG
|InterceptPattern=7880
|InterceptWhere=
|InterceptSdlProcessId=(0,0,0)
|InterceptSsType=16777228
|InterceptSsKey=6966
|InterceptSsNotifyType=1
|OverlapSendingFlagEnabled=0
|WithTags=
|WithValues=
|CallingPartyNumberPi=NotSelected
|ConnectedPartyNumberPi=NotSelected
|CallingPartyNamePi=NotSelected
|ConnectedPartyNamePi=NotSelected
|CallManagerDeviceType=NoDeviceType
|PatternPrecedenceLevel=Routine
|CallableEndPointName=[dd554baf-c660-64c2-fe60-03cd09799f1e]
|PatternNodeId=[dd554baf-c660-64c2-fe60-03cd09799f1e]
|AARNeighborhood=[]
|AARDestinationMask=[]
|AARKeepCallHistory=true
|AARVoiceMailEnabled=false
|NetworkLocation=OnNet
|Calling Party Number Type=Cisco Unified CallManager
|Calling Party Numbering Plan=Cisco Unified CallManager
|Called Party Number Type=Cisco Unified CallManager
|Called Party Numbering Plan=Cisco Unified CallManager
|ProvideOutsideDialtone=false
|AllowDeviceOverride=false
|AlternateMatches= Information Not Available
|TranslationPatternDetails= Information Not Available
|ResourcePriorityNamespace=|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:0800>
07/01/2013 13:06:31.712 CCM|Cdcc::fireCfInterceptInd: precLvl=5|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:0800>
07/01/2013 13:06:31.713 CCM|ConnectionManager - wait_AuDisconnectRequest ERROR:NO ENTRY FOUND IN TABLE,CI(21025965,0),dcType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:ERROR><:0800>
07/01/2013 13:06:31.713 CCM|MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=0, party 2 videocapable=0|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:ALL><:FFFF>
07/01/2013 13:06:31.714 CCM|//SIP/Stack/States/0xebe1610/0xebe1610 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)|<:STANDALONECLUSTER><:192.168.10.49><:1><:192.168.10.51><:><:STATE transition=""><:40000>
07/01/2013 13:06:31.714 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 192.168.10.51:[5060]:
Content-Length: 0
To: <7880>;tag=ed20608f-032f-4323-ac4c-650fe15afd77-21025965
CSeq: 102 INVITE
CSCO10659222
Refer to this site for the MWI on/off  workaround  for an  CallManager http://shaun.net/2008/05/cisco-callmanager-3-with-asterisk-vm/
