block incoming calls by caller id - CM 10.5
danseitz11
Running CM 10.5. Gateways MGCP. Some users getting annoying calls regularly. Is there a way for me to block them based on their caller id number?
Researching is getting confusing, thought best to just ask.
Jitender Bhandari
See below for help
https://supportforums.cisco.com/document/71966/blocking-calls-based-calling-party-id
(Rate if it helps)
JB
Jaime Valencia
How to block inbound calls has been discussed hundreds of times at CSC, you can find all the information you need if you just google: cisco + mgcp + block
java
if this helps, please rate
