Call PickUP CUCM 11 problem with the message status from 7962-7965 phones
Generally there CUCM v 11 (21900-11 Unrestricted), have a pickup group has 2 numbers belong to this group.
There is an option in the pickup group Call Pickup Group Notification Settings - audible and visual alert.
Everything works, the call is intercepted, alert timer to set a delay Call Pickup Group Notification Timer (seconds),
BUT! after the procedure on the devices 7962 and 7965 (3905 seems to work out), in the status bar area (where the current user settings is usually written), it remains "calling" -> "called" (visual alert).
Like it or not, changed the firmware on the SIP SCCP changed, does not help anything, it remains and does not disappear, only change when a new call to the number of the pickup group.
The Russian locale is changed to English. - The result is the same. There IP communicator on it the same situation.
Who faced ?!
CUCM Administration --> System --> Service Parameter --> Cisco CallManager
parametr 'Call Park Display Timer' must be different by 0 (10 by default).
