Calls from internal to Jabber MRA fail
I need help to understand what´s happen with my deployment.
Scenario is:
Internal Phone -> CUCM 9.1.2  ->  Exp-C 8.7.1   ->  Exp-E 8.7.1  -> Jabber MRA
Jabber MRA authenticate with no problems.
When a call is made from a SCCP or SIP phone to MRA I can see all INVITES without SDP, with changes in VIA and Record-Route, all 180 Trying coming back from Jabber and 200OK with SDP.
At this point, after 200OK arrive from Exp-C to CUCM, CUCM doesn´t reply. I can see Exp-C send retry 200OK (10 times).
Internal Phone still ringing. After internal phone go on-hook, I can see CUCM send a ACK reply to 200OK and Exp-C send a BYE with a SIP text "Missing content in ACK".
If this call is made in inverted order (from Jabber MRA to internal Phone) call is OK.
Any help to understand why CUCM doesn´t reply 200OK.
Thanks.
UPDATE
I found an Unexpected response between SIP messages in a Call with Failure.
|AppInfo |//SIP/Stack/Error/0xb2bcfc90/sact_recd_success_new_message_response: Unexpected response
56172106.003 |15:37:33.267 |AppInfo |SIPTcp - SignalCounter = 996653
56172107.000 |15:37:33.267 |SdlSig |SIPSPISignal |wait |SIPHandler(1,100,72,1) |SIPTcp(1,100,64,1) |1,100,13,179985.12^172.19.0.13^* |*TraceFlagOverrode
56172107.001 |15:37:33.267 |AppInfo |//SIP/Stack/Info/0x0/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 (SIP_NETWORK_MSG), for event 1 (SIPSPI_EV_NEW_MESSAGE)
56172107.002 |15:37:33.267 |AppInfo |//SIP/Stack/Transport/0x0/sipTransportProcessNWNewConnMsg: context=(nil)
56172107.003 |15:37:33.267 |AppInfo |//SIP/Stack/Transport/0x0/sipConnectionManagerProcessNewConnMsg: gConnTab=0xb2ac06f0, addr=172.19.0.13, port=27079, connid=131237, transport=TCP
56172107.004 |15:37:33.267 |AppInfo |//SIP/Stack/Info/0x0/sipHolderGetConnInstance: Return existing connection for port 27079 connId 131237
56172107.005 |15:37:33.267 |AppInfo |//SIP/Stack/Info/0xb2bcfc90/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
56172107.006 |15:37:33.267 |AppInfo |//SIP/Stack/Error/0xb2bcfc90/sact_recd_success_new_message_response: Unexpected response
56172108.000 |15:37:33.521 |SdlSig |DbObjectCacheTimer |initialized |Db(1,100,202,1) |SdlTimerService(1,100,3,1) |1,100,139,1.1^*^* |[T:H-H:0,N:0,L:0,V:0,Z:0,D:0] AppCorr: 0
56172109.000 |15:37:33.649 |SdlSig |SdlReadRsp |wait |SIPTcp(1,100,64,1) |SdlTCPConnection(1,100,13,179978) |1,100,13,179978.7^172.19.0.13^* |*TraceFlagOverrode
56172109.001 |15:37:33.649 |AppInfo |SIPTcp - SdlRead bufferLen=397
56172109.002 |15:37:33.649 |AppInfo |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 172.19.0.13 on port 27077 index 131231 with 397 bytes:
[3382382,NET]
Can be this my problem?
Any ideas?
