Change minimum PIN length in CUCMBE
shh5455
Level 3
Level 3
I've got CUCMBE 7 with LDAP integration. When users on Unity conneciton are asked to change their PIN it allows them a minimum length of 1. I want this to be 4. Where do I change this?
Thanks.
Hoan Mai
Try this -
CUCA>System Settings>Authentication Rules>Recommended Voice Mail Authentication Rule
Rick Mai
Hmm... I don't have that in my system settings menu. What version are you on? I'm using 7.0.2.
Oops my bad. This is for UC standalone.
For BE, you need to setup the user setting on the CM side.
Create a new Credential Policy under User management > Credential Policy.
Apply the policy to the end user by editing the PIN tab.
