Cisco CUBE ISR G2 Box to Box redudancy
_megasema_
Hi experts,
would you be so kind to advise if CUBE's box to box redudancy using the HSRP would work as per diaram attached ? The difference from the
configuration example given by Cisco is that we would like to use a subinterfaces for the inside and outside traffic so we can utilise only one
physical interface on the CUBE.
keglass
Level 7
Level 7
Andriy,
This community does not provide technical support and is not staffed with technical supportexperts. I recommend you post this and future technical support questions to the Cisco Support Community (https://supportforums.cisco.com/index.jspa) where our Cisco technical support experts provide assistance. Another option is to open a ticket with the Cisco Technical Assistance Center (www.cisco.com/go/support) to get expert assistance.
We do encourage you to participate in the Cisco Collaboration Community and to also join our Cisco Collaboration User Group program!  In the community, we encourage your discussion/sharing around collaboration topics and Cisco Collaboration Solutions, including business and IT requirements, industry trends, process, culture/organization issues, how collaboration can be used to transform businesses, vendor selection, adoption, training, architecture, licensing, and product features/functionality. If you are a customer or partner, you can also join the user group program to be eligible for member-only events and influence product direction.
We hope to hear from you again.
Kelli Glass
Moderator for the Cisco Collaboration Community
