Cisco Unity Connection 11.0 Error: Products not supported on current hardware.
Hi all,
When I try to install unity connection on Vmware, giving this error. How can I solve this problem?
My notebook is Macbook Pro 2015 and I am using vmware Fusion 8.1.1 .
Disk capacity 200GB.
2 processor.
6gb memory.
Linux Red Hat 6 - 64bit.
Thanks a lot.
Jaime Valencia
What's the CPU speed???
java
if this helps, please rate
2.2 Ghz, but the problem was about iso file. I changed my iso file and it's solved. Thank you.
