Cisco Unity Connection 8 Hardware Requirements
cr8zyeddie
     I've checked the supported servers page for a Cisco Unity Connection 8 server at http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html but need some advice. I need a server for a test lab (less than 50 users) but some of the servers listed on that page are no longer sold. I spoke to a HP rep and he told me they don't keep an updated list of certified servers, so I was hoping someone could tell me, as an example, an HP DL320 G6 is supported for this setup. It doesn't have to be that particular server, just one within that price range and hardware. If anyone has an updated supported server list that would be great too. Or, even better, if an example of a server you're currently running on would be great as well. I just want to make sure we don't purchase a server that is incompatible for something hardware related - the documentation for supported servers out there seems a bit out of date.
Thanks for your time,
Ed
Jaime Valencia
You really should be looking at the CUC documentation and not to the CUCM doc
Cisco Unity Connection 8.x Supported Platforms  List
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Ahh thanks this was exactly the document I needed.
Ed
