Cisco Webex Codec Pro RJ45 ports
Ned Kelly
Hi there,
is there a way to disable the un-used RJ45 ports on the Cisco Pro?
I have had an issue where a customer has plugged in a live network cable into the second camera port spamming the switch and ultimately killing the switch where the codec was connected.
Would appreciate any hints/help on this.
Cheers
0 Replies 0
