Cisco XCP File Transfer Manager - Not Running
marco_81
Hi all,
i'm running Cisco IM&P 11.5.1.11900-21 on virtualized environment, even if Cisco XCP File Transfer Manager has been activated, it's not Running.
I need the service running for File Transfer with MRA. Also via CLI no way to get it run. Enyone has the solution?
regards.
Jaime Valencia
The service will not start if the configuration for MFT is not in place, or if there are errors in it.
java
if this helps, please rate
Jaime Valencia
java
https://www.youtube.com/watch?v=FyfdEBJ-n0Y
for managed file transfer
and
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/database_setup/11_5_1/cup0_b_database-setup-guide-imp-115/cup0_b_database-setup-guide-imp-115_chapter_01.html
for psql setup were helpful for me.
thanks.
