Classic Unity 5.x ActiveX Audio Plug-In Permissions Issue
jcp408CONT
End customer with Unity 5.x in UM/AD integration.
All of a sudden (according to them anyway) when they try to use SA audio tool it will ask for domain level user authenticaion.  They log into SA no problem as UnityAdmin or UnityInstall both of which have full integration with AD.  Permissions Wizard says all is good too.   No combination of known Unity centric user credentials seems to work.
I cannot find any references on Cisco.com support for this nor have I located anything in this support forum (yet).
Anyone have any ideas?
Jon
Ginger Dillon
Hi -
Take a look at this post, it's a bit old, but could still apply -
https://supportforums.cisco.com/message/1190351#1190351
See if DCOM got disabled on the user's PC.
Regards, Ginger
