compatibility matrix for different UC applications
tachyon05
I have CUCM, CUC, and CER version 9.1.  I need to upgrade them to 11.5, but I couldn't find any documentation on version compatibility.  For example, if I upgrade CUCM to version 11.5, will the new CUCM version work with old CUC and CER version 9.1 or vice versa?  I imaging this should work but would like to see some official documentation before proceeding.  Thanks
Jaime Valencia
Refer to the CUC compatibility matrix and the RN of CER for that information.
java
if this helps, please rate
