CSF not registered
Anju Josua
Hi All,
I am facing problem with CSF registration
I already create the csf on call manager and install CUPC in my computer, it works well
but when i install CUPC in my client computer, some of its option turn grey.
i'm using the same user id, so i think there is no problem with the user id
i think the problem is in the computer, maybe something is blocked?
any idea about what should i check in the computer?
Anju
Anju Josua
found it by myself
you shuld set the firewall on computer to allow csf program
