CUCM 11.5 with CUBE MeetMe issue
vmorozan96
Hi everyone.
So, as the title say, I have a CUCM 11.5 installed and a cisco CUBE on a cisco 3945 router. The IOS version on router was 15.5 but I downgraded it to 15.1 because dspfarm profile 1 conference video was no avalabile.
So I am trying to make a MeetMe video conference on the CUBE, but my CUCM says rejected to CFB whatever I do.
I will leave here some sccp configuration and a debug of sccp all.
Spoiler
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server cucmIP
ccm-manager config
ccm-manager sccp local GigabitEthernet0/1
mgcp
mgcp call-agent cucmIP 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
mgcp profile default
sccp ccm cucmIP identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 1 register CFB2020
dspfarm profile 1 conference video homogeneous
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec h264 720p frame-rate 30 bitrate 2mbps
maximum conference-participants 8
maximum sessions 1
associate application SCCP
Spoiler
CUBE-MIR(config)#
Sep 18 10:15:49.895: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 1, appl_type 7
Sep 18 10:15:49.895: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr cucmIP, priority 1, port 2000
Sep 18 10:15:49.895: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 7, prof_id 1, to ipaddr cucmIP
Sep 18 10:15:49.895: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 7, appl profile 1
Sep 18 10:15:49.895: sccp_tcp_open_and_set_option: Socket 0 opened and binded to addr cucmIP - for appl_type 7, prof_id 1
Sep 18 10:15:49.895: sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to cucmIP port 2000 in progressfor appl_type 7, state 1, soc_fd 0 appl 1F37A34C
Sep 18 10:15:49.895: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:15:49.895: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 1
Sep 18 10:15:49.895: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:15:49.895: sccp_process_socket_connect_result: appl_type 7, eve 3, soc_id 0, state 1
Sep 18 10:15:49.895: sccp_setup_appl_to_tcp_conn_state: soc connected to cucmIP, for prof_id 1, appl_type 7
Sep 18 10:15:49.895: sccp_register_with_connected_ccm:
Sep 18 10:15:49.895: sccp_register_with_connected_ccm: Sending regis msg for appl_type 7, state 5
Sep 18 10:15:49.895: sccp_get_appl_serv_by_prof_id: prof_id 1 found in the CCM group 1
Sep 18 10:15:49.895: sccp_send_register_msg: Send register msg for appl_type 7, swb_soc 0, device_name CFB2020, ip_addr 12.160.1.2, ipv4_scope 2, ipv6_addr ::, ipv6_scope 0, device_type 88, protVer --> rsvp_enabled 0
Sep 18 10:15:49.895: protocol_ver 0x12000100 max_streams 8, active_streams 0
Sep 18 10:15:49.895: sccp_send_register_msg: st_ptr AA880E0
Sep 18 10:15:49.895: sccp_send_register_msg: Register msg txed in hex(including header) - len 136
Sep 18 10:15:49.895: sccp_print_hex_msg: Len:136 Hex:
80 00 00 00 00 00 00 00 01 00 00 00 43 46 42 32 30 32 30 00 00 00 00 00 F4 6E 20 22 00 00 00 00 01 00 00 00 0C A0 01 02 58 00 00 00 08 00 00 00 00 00 00 00 12 00 01 00 66 67 68 69 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sep 18 10:15:49.895: sccp_transmit_msg: sending on socket 0
Sep 18 10:15:49.895: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 136, socket 0, profile_id 1
Sep 18 10:15:49.895: sccp_generate_msg: msg_id 2 msg_len 8 pak_size 16
Sep 18 10:15:49.895: sccp_send_ip_port_msg_v1: send ip port msg with id 2, port 0
Sep 18 10:15:49.895: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 16, socket 0, profile_id 1
Sep 18 10:15:49.895: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 136
Sep 18 10:15:49.895: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 136, total pak_size 136, bytes_to_send 136
Sep 18 10:15:49.895: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 16
Sep 18 10:15:49.895: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 16, total pak_size 16, bytes_to_send 16
Sep 18 10:15:49.899: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:15:49.899: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 5
Sep 18 10:15:49.899: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
Sep 18 10:15:49.899: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
Sep 18 10:15:49.899: sccp_get_control_message: sccp cntl msg rcvd, prof_id 1, appl_type 7, msg_len 36
Sep 18 10:15:49.899: sccp_parse_control_msg: msg_ptr 1DB23BF4, msg_len 36, msg_id 157
Sep 18 10:15:49.899: sccp_parse_control_msg: glob_ccm->version 9
Sep 18 10:15:49.899: SCCP:rcvd RegisterRejectMessage
Sep 18 10:15:49.899: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:15:49.899: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
Sep 18 10:15:49.899: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 7, interval 41
Sep 18 10:16:30.899: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 1, appl_type 7
Sep 18 10:16:30.899: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr cucmIP, priority 1, port 2000
Sep 18 10:16:30.899: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 7, prof_id 1, to ipaddr cucmIP
Sep 18 10:16:30.899: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 7, appl profile 1
Sep 18 10:16:30.899: sccp_tcp_open_and_set_option: Socket 0 opened and binded to addr cucmIP - for appl_type 7, prof_id 1
Sep 18 10:16:30.899: sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to cucmIP port 2000 in progressfor appl_type 7, state 1, soc_fd 0 appl 1F37A34C
Sep 18 10:16:30.899: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:16:30.899: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 1
Sep 18 10:16:30.899: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:16:30.899: sccp_process_socket_connect_result: appl_type 7, eve 3, soc_id 0, state 1
Sep 18 10:16:30.899: sccp_setup_appl_to_tcp_conn_state: soc connected to cucmIP, for prof_id 1, appl_type 7
Sep 18 10:16:30.899: sccp_register_with_connected_ccm:
Sep 18 10:16:30.899: sccp_register_with_connected_ccm: Sending regis msg for appl_type 7, state 5
Sep 18 10:16:30.899: sccp_get_appl_serv_by_prof_id: prof_id 1 found in the CCM group 1
Sep 18 10:16:30.899: sccp_send_register_msg: Send register msg for appl_type 7, swb_soc 0, device_name CFB2020, ip_addr 12.160.1.2, ipv4_scope 2, ipv6_addr ::, ipv6_scope 0, device_type 88, protVer --> rsvp_enabled 0
Sep 18 10:16:30.899: protocol_ver 0x12000100 max_streams 8, active_streams 0
Sep 18 10:16:30.899: sccp_send_register_msg: st_ptr AA9CC60
Sep 18 10:16:30.899: sccp_send_register_msg: Register msg txed in hex(including header) - len 136
Sep 18 10:16:30.899: sccp_print_hex_msg: Len:136 Hex:
80 00 00 00 00 00 00 00 01 00 00 00 43 46 42 32 30 32 30 00 00 00 00 00 F4 6E 20 22 00 00 00 00 01 00 00 00 0C A0 01 02 58 00 00 00 08 00 00 00 00 00 00 00 12 00 01 00 65 3A 20 4E 6F 72 6D 61 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 65 6C 6F 61 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sep 18 10:16:30.899: sccp_transmit_msg: sending on socket 0
Sep 18 10:16:30.899: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 136, socket 0, profile_id 1
Sep 18 10:16:30.899: sccp_generate_msg: msg_id 2 msg_len 8 pak_size 16
Sep 18 10:16:30.899: sccp_send_ip_port_msg_v1: send ip port msg with id 2, port 0
Sep 18 10:16:30.899: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 16, socket 0, profile_id 1
Sep 18 10:16:30.899: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 136
Sep 18 10:16:30.899: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 136, total pak_size 136, bytes_to_send 136
Sep 18 10:16:30.899: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 16
Sep 18 10:16:30.899: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 16, total pak_size 16, bytes_to_send 16
Sep 18 10:16:30.899: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 5
Sep 18 10:16:30.899: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
Sep 18 10:16:30.899: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
Sep 18 10:16:30.899: sccp_get_control_message: sccp cntl msg rcvd, prof_id 1, appl_type 7, msg_len 36
Sep 18 10:16:30.899: sccp_parse_control_msg: msg_ptr 1DB23BF4, msg_len 36, msg_id 157
Sep 18 10:16:30.899: sccp_parse_control_msg: glob_ccm->version 9
Sep 18 10:16:30.899: SCCP:rcvd RegisterRejectMessage
Sep 18 10:16:30.899: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
Sep 18 10:16:30.899: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 7, interval 83
Sep 18 10:17:53.899: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 1, appl_type 7
Sep 18 10:17:53.899: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr cucmIP, priority 1, port 2000
Sep 18 10:17:53.899: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 7, prof_id 1, to ipaddr cucmIP
Sep 18 10:17:53.899: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 7, appl profile 1
Sep 18 10:17:53.899: sccp_tcp_open_and_set_option: Socket 0 opened and binded to addr cucmIP - for appl_type 7, prof_id 1
Sep 18 10:17:53.899: sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to cucmIP port 2000 in progressfor appl_type 7, state 1, soc_fd 0 appl 1F37A34C
Sep 18 10:17:53.899: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:17:53.899: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 1
Sep 18 10:17:53.899: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:17:53.899: sccp_process_socket_connect_result: appl_type 7, eve 3, soc_id 0, state 1
Sep 18 10:17:53.899: sccp_setup_appl_to_tcp_conn_state: soc connected to cucmIP, for prof_id 1, appl_type 7
Sep 18 10:17:53.899: sccp_register_with_connected_ccm:
Sep 18 10:17:53.899: sccp_register_with_connected_ccm: Sending regis msg for appl_type 7, state 5
Sep 18 10:17:53.899: sccp_get_appl_serv_by_prof_id: prof_id 1 found in the CCM group 1
Sep 18 10:17:53.899: sccp_send_register_msg: Send register msg for appl_type 7, swb_soc 0, device_name CFB2020, ip_addr 12.160.1.2, ipv4_scope 2, ipv6_addr ::, ipv6_scope 0, device_type 88, protVer --> rsvp_enabled 0
Sep 18 10:17:53.899: protocol_ver 0x12000100 max_streams 8, active_streams 0
Sep 18 10:17:53.899: sccp_send_register_msg: st_ptr AAB58E0
Sep 18 10:17:53.899: sccp_send_register_msg: Register msg txed in hex(including header) - len 136
Sep 18 10:17:53.899: sccp_print_hex_msg: Len:136 Hex:
80 00 00 00 00 00 00 00 01 00 00 00 43 46 42 32 30 32 30 00 00 00 00 00 F4 6E 20 22 00 00 00 00 01 00 00 00 0C A0 01 02 58 00 00 00 08 00 00 00 00 00 00 00 12 00 01 00 23 67 68 69 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sep 18 10:17:53.899: sccp_transmit_msg: sending on socket 0
Sep 18 10:17:53.899: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 136, socket 0, profile_id 1
Sep 18 10:17:53.899: sccp_generate_msg: msg_id 2 msg_len 8 pak_size 16
Sep 18 10:17:53.899: sccp_send_ip_port_msg_v1: send ip port msg with id 2, port 0
Sep 18 10:17:53.899: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 16, socket 0, profile_id 1
Sep 18 10:17:53.899: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 136
Sep 18 10:17:53.899: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 136, total pak_size 136, bytes_to_send 136
Sep 18 10:17:53.899: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 16
Sep 18 10:17:53.899: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 16, total pak_size 16, bytes_to_send 16
Sep 18 10:17:53.901: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:17:53.901: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 5
Sep 18 10:17:53.901: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
Sep 18 10:17:53.901: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
Sep 18 10:17:53.901: sccp_get_control_message: sccp cntl msg rcvd, prof_id 1, appl_type 7, msg_len 36
Sep 18 10:17:53.901: sccp_parse_control_msg: msg_ptr 1DB23BF4, msg_len 36, msg_id 157
Sep 18 10:17:53.901: sccp_parse_control_msg: glob_ccm->version 9
Sep 18 10:17:53.901: SCCP:rcvd RegisterRejectMessage
Sep 18 10:17:53.901: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:17:53.901: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
Sep 18 10:17:53.901: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 7, interval 42
Sep 18 10:18:35.901: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 1, appl_type 7
Sep 18 10:18:35.901: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr cucmIP, priority 1, port 2000
Sep 18 10:18:35.901: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 7, prof_id 1, to ipaddr cucmIP
Sep 18 10:18:35.901: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 7, appl profile 1
Sep 18 10:18:35.901: sccp_tcp_open_and_set_option: Socket 0 opened and binded to addr cucmIP - for appl_type 7, prof_id 1
Sep 18 10:18:35.901: sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to cucmIP port 2000 in progressfor appl_type 7, state 1, soc_fd 0 appl 1F37A34C
Sep 18 10:18:35.901: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:18:35.901: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 1
Sep 18 10:18:35.901: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:18:35.901: sccp_process_socket_connect_result: appl_type 7, eve 3, soc_id 0, state 1
Sep 18 10:18:35.901: sccp_setup_appl_to_tcp_conn_state: soc connected to cucmIP, for prof_id 1, appl_type 7
Sep 18 10:18:35.901: sccp_register_with_connected_ccm:
Sep 18 10:18:35.901: sccp_register_with_connected_ccm: Sending regis msg for appl_type 7, state 5
Sep 18 10:18:35.901: sccp_get_appl_serv_by_prof_id: prof_id 1 found in the CCM group 1
Sep 18 10:18:35.901: sccp_send_register_msg: Send register msg for appl_type 7, swb_soc 0, device_name CFB2020, ip_addr 12.160.1.2, ipv4_scope 2, ipv6_addr ::, ipv6_scope 0, device_type 88, protVer --> rsvp_enabled 0
Sep 18 10:18:35.901: protocol_ver 0x12000100 max_streams 8, active_streams 0
Sep 18 10:18:35.901: sccp_send_register_msg: st_ptr AAC28E0
Sep 18 10:18:35.901: sccp_send_register_msg: Register msg txed in hex(including header) - len 136
Sep 18 10:18:35.901: sccp_print_hex_msg: Len:136 Hex:
80 00 00 00 00 00 00 00 01 00 00 00 43 46 42 32 30 32 30 00 00 00 00 00 F4 6E 20 22 00 00 00 00 01 00 00 00 0C A0 01 02 58 00 00 00 08 00 00 00 00 00 00 00 12 00 01 00 5F 6D 73 67 5F 6E 6F 6E 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 65 73 73 61 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sep 18 10:18:35.901: sccp_transmit_msg: sending on socket 0
Sep 18 10:18:35.901: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 136, socket 0, profile_id 1
Sep 18 10:18:35.901: sccp_generate_msg: msg_id 2 msg_len 8 pak_size 16
Sep 18 10:18:35.901: sccp_send_ip_port_msg_v1: send ip port msg with id 2, port 0
Sep 18 10:18:35.901: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 16, socket 0, profile_id 1
Sep 18 10:18:35.901: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 136
Sep 18 10:18:35.901: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 136, total pak_size 136, bytes_to_send 136
Sep 18 10:18:35.901: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 16
Sep 18 10:18:35.901: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 16, total pak_size 16, bytes_to_send 16
Sep 18 10:18:35.903: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:18:35.903: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 5
Sep 18 10:18:35.903: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
Sep 18 10:18:35.903: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
Sep 18 10:18:35.903: sccp_get_control_message: sccp cntl msg rcvd, prof_id 1, appl_type 7, msg_len 36
Sep 18 10:18:35.903: sccp_parse_control_msg: msg_ptr 1DB23BF4, msg_len 36, msg_id 157
Sep 18 10:18:35.903: sccp_parse_control_msg: glob_ccm->version 9
Sep 18 10:18:35.903: SCCP:rcvd RegisterRejectMessage
Sep 18 10:18:35.903: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:18:35.903: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
Sep 18 10:18:35.903: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 7, interval 49
Sep 18 10:19:24.903: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 1, appl_type 7
Sep 18 10:19:24.903: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr cucmIP, priority 1, port 2000
Sep 18 10:19:24.903: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 7, prof_id 1, to ipaddr cucmIP
Sep 18 10:19:24.903: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 7, appl profile 1
Sep 18 10:19:24.903: sccp_tcp_open_and_set_option: Socket 0 opened and binded to addr cucmIP - for appl_type 7, prof_id 1
Sep 18 10:19:24.903: sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to cucmIP port 2000 in progressfor appl_type 7, state 1, soc_fd 0 appl 1F37A34C
Sep 18 10:19:24.903: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:19:24.903: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 1
Sep 18 10:19:24.903: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:19:24.903: sccp_process_socket_connect_result: appl_type 7, eve 3, soc_id 0, state 1
Sep 18 10:19:24.903: sccp_setup_appl_to_tcp_conn_state: soc connected to cucmIP, for prof_id 1, appl_type 7
Sep 18 10:19:24.903: sccp_register_with_connected_ccm:
Sep 18 10:19:24.903: sccp_register_with_connected_ccm: Sending regis msg for appl_type 7, state 5
Sep 18 10:19:24.903: sccp_get_appl_serv_by_prof_id: prof_id 1 found in the CCM group 1
Sep 18 10:19:24.903: sccp_send_register_msg: Send register msg for appl_type 7, swb_soc 0, device_name CFB2020, ip_addr 12.160.1.2, ipv4_scope 2, ipv6_addr ::, ipv6_scope 0, device_type 88, protVer --> rsvp_enabled 0
Sep 18 10:19:24.903: protocol_ver 0x12000100 max_streams 8, active_streams 0
Sep 18 10:19:24.903: sccp_send_register_msg: st_ptr AADB560
Sep 18 10:19:24.903: sccp_send_register_msg: Register msg txed in hex(including header) - len 136
Sep 18 10:19:24.903: sccp_print_hex_msg: Len:136 Hex:
80 00 00 00 00 00 00 00 01 00 00 00 43 46 42 32 30 32 30 00 00 00 00 00 F4 6E 20 22 00 00 00 00 01 00 00 00 0C A0 01 02 58 00 00 00 08 00 00 00 00 00 00 00 12 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sep 18 10:19:24.903: sccp_transmit_msg: sending on socket 0
Sep 18 10:19:24.903: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 136, socket 0, profile_id 1
Sep 18 10:19:24.903: sccp_generate_msg: msg_id 2 msg_len 8 pak_size 16
Sep 18 10:19:24.903: sccp_send_ip_port_msg_v1: send ip port msg with id 2, port 0
Sep 18 10:19:24.903: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 16, socket 0, profile_id 1
Sep 18 10:19:24.903: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 136
Sep 18 10:19:24.903: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 136, total pak_size 136, bytes_to_send 136
Sep 18 10:19:24.903: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 16
Sep 18 10:19:24.903: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 16, total pak_size 16, bytes_to_send 16
Sep 18 10:19:24.905: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:19:24.905: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 5
Sep 18 10:19:24.905: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
Sep 18 10:19:24.905: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
Sep 18 10:19:24.905: sccp_get_control_message: sccp cntl msg rcvd, prof_id 1, appl_type 7, msg_len 36
Sep 18 10:19:24.905: sccp_parse_control_msg: msg_ptr 1DB23BF4, msg_len 36, msg_id 157
Sep 18 10:19:24.905: sccp_parse_control_msg: glob_ccm->version 9
Sep 18 10:19:24.905: SCCP:rcvd RegisterRejectMessage
Sep 18 10:19:24.905: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:19:24.905: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
Sep 18 10:19:24.905: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 7, interval 42
Sep 18 10:20:06.905: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 1, appl_type 7
Sep 18 10:20:06.905: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr cucmIP, priority 1, port 2000
Sep 18 10:20:06.905: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 7, prof_id 1, to ipaddr cucmIP
Sep 18 10:20:06.905: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 7, appl profile 1
Sep 18 10:20:06.905: sccp_tcp_open_and_set_option: Socket 0 opened and binded to addr cucmIP - for appl_type 7, prof_id 1
Sep 18 10:20:06.905: sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to cucmIP port 2000 in progressfor appl_type 7, state 1, soc_fd 0 appl 1F37A34C
Sep 18 10:20:06.905: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:20:06.905: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 1
Sep 18 10:20:06.905: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:20:06.905: sccp_process_socket_connect_result: appl_type 7, eve 3, soc_id 0, state 1
Sep 18 10:20:06.905: sccp_setup_appl_to_tcp_conn_state: soc connected to cucmIP, for prof_id 1, appl_type 7
Sep 18 10:20:06.905: sccp_register_with_connected_ccm:
Sep 18 10:20:06.905: sccp_register_with_connected_ccm: Sending regis msg for appl_type 7, state 5
Sep 18 10:20:06.905: sccp_get_appl_serv_by_prof_id: prof_id 1 found in the CCM group 1
Sep 18 10:20:06.905: sccp_send_register_msg: Send register msg for appl_type 7, swb_soc 0, device_name CFB2020, ip_addr 12.160.1.2, ipv4_scope 2, ipv6_addr ::, ipv6_scope 0, device_type 88, protVer --> rsvp_enabled 0
Sep 18 10:20:06.905: protocol_ver 0x12000100 max_streams 8, active_streams 0
Sep 18 10:20:06.905: sccp_send_register_msg: st_ptr AAF0420
Sep 18 10:20:06.905: sccp_send_register_msg: Register msg txed in hex(including header) - len 136
Sep 18 10:20:06.905: sccp_print_hex_msg: Len:136 Hex:
80 00 00 00 00 00 00 00 01 00 00 00 43 46 42 32 30 32 30 00 00 00 00 00 F4 6E 20 22 00 00 00 00 01 00 00 00 0C A0 01 02 58 00 00 00 08 00 00 00 00 00 00 00 12 00 01 00 69 67 2D 64 73 70 66 61 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 63 69 61 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sep 18 10:20:06.905: sccp_transmit_msg: sending on socket 0
Sep 18 10:20:06.905: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 136, socket 0, profile_id 1
Sep 18 10:20:06.905: sccp_generate_msg: msg_id 2 msg_len 8 pak_size 16
Sep 18 10:20:06.905: sccp_send_ip_port_msg_v1: send ip port msg with id 2, port 0
Sep 18 10:20:06.905: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 16, socket 0, profile_id 1
Sep 18 10:20:06.905: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 136
Sep 18 10:20:06.905: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 136, total pak_size 136, bytes_to_send 136
Sep 18 10:20:06.905: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 16
Sep 18 10:20:06.905: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 16, total pak_size 16, bytes_to_send 16
Sep 18 10:20:06.907: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:20:06.907: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 5
Sep 18 10:20:06.907: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
Sep 18 10:20:06.907: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
Sep 18 10:20:06.907: sccp_get_control_message: sccp cntl msg rcvd, prof_id 1, appl_type 7, msg_len 36
Sep 18 10:20:06.907: sccp_parse_control_msg: msg_ptr 1DB23BF4, msg_len 36, msg_id 157
Sep 18 10:20:06.907: sccp_parse_control_msg: glob_ccm->version 9
Sep 18 10:20:06.907: SCCP:rcvd RegisterRejectMessage
Sep 18 10:20:06.907: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:20:06.907: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
Sep 18 10:20:06.907: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 7, interval 31
Sep 18 10:20:37.907: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 1, appl_type 7
Sep 18 10:20:37.907: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr cucmIP, priority 1, port 2000
Sep 18 10:20:37.907: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 7, prof_id 1, to ipaddr cucmIP
Sep 18 10:20:37.907: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 7, appl profile 1
Sep 18 10:20:37.907: sccp_tcp_open_and_set_option: Socket 0 opened and binded to addr cucmIP - for appl_type 7, prof_id 1
Sep 18 10:20:37.907: sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to cucmIP port 2000 in progressfor appl_type 7, state 1, soc_fd 0 appl 1F37A34C
Sep 18 10:20:37.907: sccpapp_process_socket_events: appl_type 7, soc_fd 0, soc 0, swb_soc -1
Sep 18 10:20:37.907: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 1
Sep 18 10:20:37.907: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:20:37.907: sccp_process_socket_connect_result: appl_type 7, eve 3, soc_id 0, state 1
Sep 18 10:20:37.907: sccp_setup_appl_to_tcp_conn_state: soc connected to cucmIP, for prof_id 1, appl_type 7
Sep 18 10:20:37.907: sccp_register_with_connected_ccm:
Sep 18 10:20:37.907: sccp_register_with_connected_ccm: Sending regis msg for appl_type 7, state 5
Sep 18 10:20:37.907: sccp_get_appl_serv_by_prof_id: prof_id 1 found in the CCM group 1
Sep 18 10:20:37.907: sccp_send_register_msg: Send register msg for appl_type 7, swb_soc 0, device_name CFB2020, ip_addr 12.160.1.2, ipv4_scope 2, ipv6_addr ::, ipv6_scope 0, device_type 88, protVer --> rsvp_enabled 0
Sep 18 10:20:37.907: protocol_ver 0x12000100 max_streams 8, active_streams 0
Sep 18 10:20:37.907: sccp_send_register_msg: st_ptr AB01520
Sep 18 10:20:37.907: sccp_send_register_msg: Register msg txed in hex(including header) - len 136
Sep 18 10:20:37.907: sccp_print_hex_msg: Len:136 Hex:
80 00 00 00 00 00 00 00 01 00 00 00 43 46 42 32 30 32 30 00 00 00 00 00 F4 6E 20 22 00 00 00 00 01 00 00 00 0C A0 01 02 58 00 00 00 08 00 00 00 00 00 00 00 12 00 01 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sep 18 10:20:37.907: sccp_transmit_msg: sending on socket 0
Sep 18 10:20:37.907: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 136, socket 0, profile_id 1
Sep 18 10:20:37.907: sccp_generate_msg: msg_id 2 msg_len 8 pak_size 16
Sep 18 10:20:37.907: sccp_send_ip_port_msg_v1: send ip port msg with id 2, port 0
Sep 18 10:20:37.907: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 16, socket 0, profile_id 1
Sep 18 10:20:37.907: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 136
Sep 18 10:20:37.907: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 136, total pak_size 136, bytes_to_send 136
Sep 18 10:20:37.907: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0, pak size 16
Sep 18 10:20:37.907: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 1, sent bytes 16, total pak_size 16, bytes_to_send 16
Sep 18 10:20:37.907: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 7, eve 4, state 5
Sep 18 10:20:37.907: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
Sep 18 10:20:37.907: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
Sep 18 10:20:37.907: sccp_get_control_message: sccp cntl msg rcvd, prof_id 1, appl_type 7, msg_len 36
Sep 18 10:20:37.909: sccp_parse_control_msg: msg_ptr 1DB23BF4, msg_len 36, msg_id 157
Sep 18 10:20:37.909: sccp_parse_control_msg: glob_ccm->version 9
Sep 18 10:20:37.909: SCCP:rcvd RegisterRejectMessage
Sep 18 10:20:37.909: sccp_appl_service_stop_timer: Stop 1F37A3A0 timer
Sep 18 10:20:37.909: sccp_parse_control_msg_v1: rcvd register rej, reason: Error: DB Config
Sep 18 10:20:37.909: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 1, appl_type 7, interval 41
Jaime Valencia
Video on dspfarms was deprecated many years ago, you should not be attempting to use that feature and use a proper video CFB like CMS into your design.
java
if this helps, please rate
vmorozan96
In my oranization purchasing goes pretty hard, I am currently waiting a CMS to be purchased, but I will really need a confernce like the end of the next week.
I remembered I dit that meetme with video last summer and it worked perfectly.
I know that CMS would do the job better but now I just want to fix this one.
That was deprecated almost 5 years ago
https://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/bulletin-c25-735945.html
I doubt any current CUCM release will have the code required to handle such feature.
Suggest you look for alternatives, either use Webex or do a voice only conference with your CUCM/ISR
java
