08-03-2012 07:02 AM - edited 03-19-2019 05:19 AM
Hello all.
Yesterday we have migrated our telephone infrastructure from CM4.x to CUCM8.6(2), after some weeks of tests.
Yesterday night all seems to work properly, all phone updated and registered, external calls going out and in.
But from this morning, with all users at work, it appears a strange problem, that until now I couldn't solve: randomly all external calls go down.
I can't address this problem, since gateways (all cisco 2811 routers) are the same and with same configuration as yesterday.
All thing that I can think is that router that seems to cause the problem is configured not with mgcp by cucm, but with h323 route inside the router.
Any suggestions will be greatly appreciated.
Daniele
08-03-2012 10:46 AM
What does the debugs on the GW say about the disconnect cause and who's issuing it?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-04-2012 01:01 AM
GW says normal call clearing.
But, maybe I've addressed the problem.
I've found a bug fixed into latest cucm release (8.6(2a)SU1) that say "h.323 calls improperly disconnected".
So I'm trying to upgrade from 8.6(2a) to 8.6(2a)SU1, but process fails :-(
I've tried from a dvd and also loading iso image from sftp, but after few minutes appears an error
08/04/2012 09:43:55 upgrade_install.sh|Started auditd...|<:INFO>
08/04/2012 09:43:56 upgrade_install.sh|Started setroubleshoot...|<:INFO>
08/04/2012 09:43:56 upgrade_install.sh|Changed selinux mode to enforcing|<:INFO>
08/04/2012 09:43:56 upgrade_install.sh|Cleaning up rpm_archive...|<:INFO>
08/04/2012 09:43:56 upgrade_install.sh|Removing /common/rpm-archive/8.6.2.21900-5|<:INFO>
08/04/2012 09:43:56 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:599, Function: main(), Upgrade Failed -- (1)|<:ERROR>
08/04/2012 09:43:56 upgrade_install.sh|set_upgrade_result: set to 1|<:DEBUG>
08/04/2012 09:43:56 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<:DEBUG>
08/04/2012 09:43:56 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 1286).|<:DEBUG>
08/04/2012 09:43:56 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 1286)|<:DEBUG>
I've rebooted server yet and problem remains.
Thanks for any other suggestions.
Daniele
08-05-2012 02:25 PM
Anyone can help me?
I've read about a bug that can disconnect h323 calls, and this bug is solved in 8.6(2a)SU1 version, but I can't install this version into our 8.6(2a) cucm...
Problem is always the same, also after a reboot:
How can I install this upgrade?
Thanks a lot!
Daniele
08-06-2012 12:03 AM
11-03-2014 09:28 PM
Hello dimensyssrl,
could you resolve that issue? Facing the same situation now, updates fails with the same error.
Version UCSInstall_UCOS_8.6.2.22900-9 >>> UCSInstall_UCOS_8.6.2.23900-10
Thanks in advance,
Daniel
