CUCM 8.6 clustering issue
We newly configured CUCM 8.6 server 2 Nos. Such as First node Publisher and subsequent node is subscriber, Both servers are reachable unable to synchronize. When i try to create CM group can see one server.
Also now its running on Demo version, The Demo version is there any limitations for clustering ?
Please let u know need additional info.
The report xml file attached.
Thank You
S.Rajkumar
Jaime Valencia
Have you enabled the CUCM service on both servers??
java
if this helps, please rate
Hi Javalenc,
Thanks for your support,
But unable to enable CUCM Service on subscriber node
The error message says "Cisco CallManager Service cannot be Activated or Deactivated due to Database Update Failure"
We also try this method which below on the link.
https://learningnetwork.cisco.com/thread/31253
Reset security password, and followed those steps on document until reset dbreplication all in Publiser(First Node).
Still the same, Unable to start CUCM service or do not have DB replication.
Note:
We try the security password reset, after that cannot login using that same password to security login,
Is it normal?
Please let us know if need further info.
Thank You
S.Rajkumar
