CUCM deny call forward between partitions
aggranilloa
Hi all, we have a customer request for call forward feature.
The scenario
- 1 partition named "ISOLATED"
- 1 partition named "INTERNALS"
- 1 partition named "EXTERNAL"
The question:
The INTERNALS can call to the ISOLATED and to the EXTERNALS
The INTERNALS not must can transfer calls to the ISOLATED.
The INTERNALS must can transfer calls to the EXTERNALS
How can I accomplish this?
Thanks.
Jaime Valencia
The same CSSs you use to call, are used for transfer, there is no way to do what you're asking.
java
if this helps, please rate
