CUCM Dhcp question
Jonn cos
Level 4
Level 4
Hi all experts.
In CUCM 7.x, if i am using DHCP to assign IP to ip phones, can i track any ip phone's IP via its extension ?
For example, there is John with extension 1001. If i want to know, what ip is currently used by IP phone, can i see it ?
Thanks in advance
mdawar
Hi John
I believe on device pages, if you find phones with Directory number of 1001, you should be able to see the IP Address.
However if from CUCM DHCP you want to track the IP addresses leased, then it is not possible.
Checkout this bug CSCsj25094
Also, note that Cisco recomments DHCP on CUCM servers only for specific deployments.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/netstruc.html#wp1184975
Regard..
Mahesh Dawar
www.cisco.com/go/pdihelpdesk
Dear Sir,
Thanks alot for the prompt response. I will check today and let you know tomorrow.
Thanks again
